Good mail order place for battery cables? - Page 4 - SailNet Community
 7Likes
post #31 of 35 Old 12-19-2013 Thread Starter
Re: Good mail order place for battery cables?
BTW, is it considered good practice to run + battery cables through plastic conduit? About half of my cables are, and half aren't.
MarkSF is offline
post #32 of 35 Old 12-20-2013
Asleep at the wheel
jimgo's Avatar
It makes for a cleaner run, makes it easier to replace them, and may cut down on chaffing.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #33 of 35 Old 12-20-2013
Maine Sail's Avatar
Ditto.. Not a requirement but a nice to have feature.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #34 of 35 Old 12-23-2013 Thread Starter
Just finished installing 2/0 cables from genuinedealz.com, a new Blue Sea Systems battery switch, and fuses at the battery. Looks good and the engine starts nicely.
I put the + cable through Ancor conduit, and cable tied the -ve cable to that.
One odd thing I found : someone had installed a battery meter, and ran the wires to the battery switch. They used 18 gauge untinned wires, and had to cut open the rings on the crimps to make them fit. No fuses, so two unfused 6ft runs of not-to-code wire through the engine compartment.
I can't think of any reason not to connect the voltmeter at the battery charger terminals. It is permanently connected to both batteries, and only 1ft away from the voltmeter!
I plan to add inline fuses, this time.
Can anyone else think of a reason this won't work?
MarkSF is offline
post #35 of 35 Old 04-22-2014
L124C's Avatar
Originally Posted by BELLATRIX1965 View Post
Since you asked about "mail order" - For the very best prices, service and FREE shipping, I exclusively use Marine Wiring, Boat Cable and Electrical Genuinedealz.com. They use only high-grade marine tinned cable, and will properly crimp end connectors (they also sell all the necessary bits and bobs) for only $1 per crimp. This includes installing adhesive-lined heat shrink (which you have to buy also, but it's cheap).
No affiliation - I have used these folks for years and they are GREAT! Good luck with your project!
In addition, the wire they sell is made in the USA. I always receive the order on the West Coast within 3 days, usually 2. Very satisfied!
L124C is offline
Mail Order Yanmar Parts in Puget Sound? Rusty123 Diesel 1 07-17-2013 02:25 PM
Speedseal -- best place to order? Rusty123 Gear & Maintenance 17 04-22-2013 12:29 AM
Battery wires and cables? ImASonOfaSailor General Discussion (sailing related) 4 04-07-2012 07:38 PM
Battery Cables and Crimpers arf145 Electrical Systems 16 12-02-2009 10:25 PM
Sizing battery cables scosch Gear & Maintenance 9 11-09-2007 01:35 AM
