Gas gauge/sensor problem - SailNet Community
 1Likes
post #1 of 11 Old 12-09-2013 Thread Starter
Hi All, I have a 77' Islander 32 and the gas gauge lights up but the needle doesn't move, even after I fill the tank. My question is: could this be the sensor in the tank, and if so, where would it be located on the tank/what would it look like? I'm assuming its an older float type sensor since it looks like the original tank, and it would have to have a wire going to it, right?
I plan on tracing the wires from the gauge to the box but the gauge light is working so it has to have juice going to it. And it looks like a new gauge compared to the others on the panel.
Just bought this and didn't notice the gauge issue earlier.
Thanks for yer help!
Lothario is offline
post #2 of 11 Old 12-09-2013
Re: Gas gauge/sensor problem
The light behind the gauge could easily be on a different cct than the gauge itself.. you wouldn't need the light in daylight so I'd guess all your gauge lighting is on another cct.
Could be as simple as a loose wire at the gauge or at the tank too... (independent of the lamp)
Faster is online now
The Following User Says Thank You to Faster For This Useful Post:
Lothario (12-11-2013)
post #3 of 11 Old 12-09-2013
olddog60's Avatar
I found this some where and used it to test my gauges.
Test Procedure For Fuel Gauges Used By Catalina Yachts
There are four components in the fuel gauge system on Catalina Yachts and therefore four possible sources of fuel gauge problems:
1) The fuel gauge in the engine control panel may be defective.
Test procedure: Disconnect the pink sender wire from “S” (sender) terminal on gauge. Turn on the ignition switch. Pointer must deflect to extreme left. By temporarily shorting together the “S” and the “G” (ground) studs, pointer must deflect to the extreme right. Re-connect the pink sender wire to the gauge after the test.
2) The pink sender wire may be disconnected from the sending unit at the tank or shorted to ground.
Test procedure: Disconnect pink sender wire from terminal on sending unit in Tank. Attach pink wire to a known ground, such as engine block or battery negative. Do not assume that fuel tank is grounded. Turn on ignition switch. Pointer must deflect to extreme right, as in previous test. Disconnect pink wire from ground. If pointer still deflects to extreme right, pink wire is grounded at some point between the sender and gauge. Check all connection points on pink wire or replace the entire wire.
3) The black ground wire may be disconnected from the sending unit at the tank or not grounded at the other end.
Test procedure: If the gauge tests “good” and pink wire tests “good” attach pink wire to the black ground wire on the sending unit at the tank. If pointer does not deflect to right (as in test above) the black wire is not grounded. Follow the black wire from the sending unit in the tank and make sure it eventually connects to ground.
4) The sending unit in the tank may be defective or the wrong unit may have been installed.
Test procedure: If the gauge tests “good”, the pink wire test “good”, and the black ground wire tests “good” the sending unit in the tank is defective or the wrong unit may have been installed. The specifications of the correct sending unit are: Stewart Warner, 240 to 33 ohms resistance. There are several other resistance specifications available but those sending units will not work in this application.
jimgo likes this.
olddog60 is offline
The Following User Says Thank You to olddog60 For This Useful Post:
post #4 of 11 Old 12-11-2013 Thread Starter
Thanks you guys! I checked it today and there is power going to all four connections in the back of the gauge and at the sensor itself. Gonna try olddog60's test procedure on it next. I should have made note of the gauge manufacturer but didn't Noticed quite a bit of corrosion back there too so a good cleanup and tightening is in order.
I did notice a small rectangular part free of the panel but in the overall circuit that had "15A" on it, and I'm assuming this is an in line fuse; it had power only on one side. This may be the culprit but will have to map out the schematics for this further. Everything else on the panel works tho...
Lothario is offline
post #5 of 11 Old 12-11-2013
chucklesR's Avatar
A picture would help, but I'll go out on a limb and say that the rectangle thing is supposed to hold a fuse. Put one in and you'll have power to both sides - and to the sending unit.
chucklesR is offline
post #6 of 11 Old 12-11-2013
Learning the HARD way...
eherlihy's Avatar
Do ANY of the gauges work? I am having trouble imagining that only the fuel gauge is protected by a fuse...
On my boat there is an ATM 20 fuse, which goes to the key switch.
One of my pet peeves lately has been with owners that do not have an up to date schematic of their boat's primary electrical system. Here is a recent copy of mine that you can use as an example (I'm not saying it is a good example, just an example);
I created this in PPT, and update this as frequently as I make changes, such as changing a fuse type or rewiring the batteries.
eherlihy is online now
The Following User Says Thank You to eherlihy For This Useful Post:
post #7 of 11 Old 12-11-2013 Thread Starter
I tried to take a pic but my crappy phone doesn't have flash and the pen light didn't do anything..and btw all the gauges work, even the gas gauge lights up as previously mentioned, the needle just doesn't work.
@eherlihy..thanks for the schematic..I've been looking for an Islander specific one to no avail and have resigned myself to starting one from scratch, so your pic will be helpful.
My next step is to replace that fuse and see what happens, just don't get that that fuse would be dedicated to one part of one gauge (since everything else works). The joy of boat ownership!
Lothario is offline
post #8 of 11 Old 12-11-2013
olddog60's Avatar
95% of the time it will be the sender. Check the resistance of the sender at the fuel tank. 240 to 30 for American and 30 to 0 for EU.
olddog60 is offline
post #9 of 11 Old 12-16-2013
Stu Jackson's Avatar
And while you're at it, next year start to take measurements of engine hours and fuel consumption. Once you KNOW the fuel use, you'll rely less on the stupid gauge.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #10 of 11 Old 12-19-2013 Thread Starter
Update: Well, I did the tests provided by olddog60 (thanks again!) and it turned out to be the sending unit after all, its ordered and on the way.
Lothario is offline
Alternator/Voltage gauge problem, 5411 diesel Marcobowow Diesel 14 12-19-2011 01:58 PM
A sensor maybe davidpm Gear & Maintenance 8 12-09-2009 09:11 PM
Propane Sensor going off... Sailormann Gear & Maintenance 15 07-20-2007 11:42 PM
Gas Gauge drynoc Gear & Maintenance 2 11-27-2006 08:09 AM
speed Sensor KenD Gear & Maintenance 0 10-23-2003 12:12 PM
