Galvanic isolator question for the electrical experts - SailNet Community
post #1 of 4 Old 12-25-2013 Thread Starter
I have a galvanic isolator, and I can see where the output side is connected to a bus that sends green wires to all the A/C outlets.
What I can't see is a connection between this bus and the DC ground. I could have one and it's hidden. But to make sure, is it a simple matter of running a wire from the bus to a good DC ground (ie, the engine in my case)?
My understanding is that this is necessary for safety.
MarkSF is offline
post #2 of 4 Old 12-25-2013
mitiempo's Avatar
Re: Galvanic isolator question for the electrical experts
That is correct, per ABYC. To make sure measure for continuity between the DC negative and the AC ground (green wire) bus with a simple multimeter.
A simpler solution for the wiring is a 10 awg green wire between the DC negative bus and the AC ground bus. Best to keep only one ground connection to the engine.
Brian
mitiempo is offline
post #3 of 4 Old 12-25-2013 Thread Starter
Good point, those two buses are within a foot of each other inside the breaker box!
MarkSF is offline
post #4 of 4 Old 12-25-2013
If you search the web, you'll find some differing opinions on grounding theory. This West Marine article does a good job explaining most of the concepts though.
http://www.westmarine.com/webapp/wcs...s#.UrqNv3q9KK0
1981 Spirit 28 "Bonnie Lass"
Bremerton, Washington
Rusty123 is offline
Testing Your Galvanic Isolator Maine Sail Gear & Maintenance 15 01-01-2013 04:08 PM
How to make your own Galvanic Isolator for under $20 yandina Gear & Maintenance 14 12-13-2012 11:14 AM
Galvanic Isolator Question Allanbc Electrical Systems 9 03-16-2011 06:51 AM
Galvanic isolator Minnewaska Gear & Maintenance 1 09-14-2010 11:57 AM
Galvanic Isolator for Crealock 34 HankJordan Pacific Seacraft 1 07-20-2008 06:58 AM
