Use of conduit to tidy up cables - Page 2 - SailNet Community
 1Likes
post #11 of 18 Old 01-01-2014
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: Use of conduit to tidy up cables
Originally Posted by newhaul View Post
Auto makers do it every day just make sure wires are correct sized for their load. The hi volt wires (110 here) are better not in closed they develops more heat to disapate. Homes here don't put them in plastic wire looms like that.
Homes are built as cheaply as possible.. but in areas that will see exposed use, wires are enclosed in metal conduit all the time.. either rigid or flexible. The point is though, there are not many wires in that conduit.. most times just a ground, neutral, and a hot.. maybe, just maybe, two separate circuits.
Properly sized, wire can get warm, but never hot enough to burn
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #12 of 18 Old 01-01-2014 Thread Starter
Well I looked around, and Bristol ran most of the 110V lines inside the plastic conduit, so I think I should be OK adding it to this part of the 110V line. Maybe I should check how warm it's getting, next time the fan heater is on and drawing 15A.
MarkSF is offline
post #13 of 18 Old 01-01-2014
pdqaltair's Avatar
I boils down to the need for physical protection; if the locker could have traffic or storage, something must be done, if not, it only makes troubleshooting take longer. Last longer? If there are enough straps, the wire will last as long as the boat unless physically damaged. Comparing the vibration on a car with a boat is apples to hand grenades. The other reasons wire is loomed on a car is manufacture and maintenance; manufacture goes faster and mechanics are kept out of the bundles. They can also consult the manual and know what is in the bundle and where things go. Totally different.
That said, I've loomed wires a few places, where they are outside dedicated panels or voids. Sometimes a physical cover or guard is an even better idea, if stuff can shift of a person fall.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
pdqaltair is offline
post #14 of 18 Old 01-02-2014
Senior Moment Member
SloopJonB's Avatar
Originally Posted by boatpoker View Post
You cannot mount a charger over batteries.
Why not? How far away must they be separated?
SloopJonB is offline
post #15 of 18 Old 01-02-2014
mitiempo's Avatar
You can but the off gassing from the batteries will corrode its internals and its life will be shortened. Assuming flooded batteries of course. In a separate compartment works well if the batteries are still close to the charger.
Brian
mitiempo is offline
post #16 of 18 Old 01-02-2014
Maine Sail's Avatar
There are however caveats...
Until you have high resistance...... I see "properly sized" melted and burned wire all the time due to high resistance....
Until you have a dead short.... Fire a dead short from a battery bank into an unfused but otherwise properly sized wire and it will go to flames...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #17 of 18 Old 01-02-2014
Maine Sail's Avatar
If the charger is not also "IP" or ignition protection rated then it is not advised to mount it even in close proximity. This charger is IP32 rated but still not advisable to mount one in a battery compartment, if it can be avoided...
"True Charge 2
This battery charger is ignition protected
equipment, so it can be installed in areas
containing gasoline tanks or fittings which require
ignition-protected equipment. Nevertheless, Xantrex
recommends that it is safest not to install any kind of
electrical equipment including the Truecharge2 Battery
Charger in these areas.
The Truecharge2 Battery Charger should be installed as
close as possible to the batteries, but not in the same
compartment to prevent corrosion.
Avoid excessive cable
lengths and use the recommended wire sizes. Xantrex
recommends installing with cables sized to achieve less
than 3% voltage drop on battery cables under full load.
This will maximize the performance of the charger."
______
post #18 of 18 Old 01-02-2014
Dirt Free
boatpoker's Avatar
As Mitiempo said "gassing". Batteries produce hydrogen gas when charging. Hydrogen is lighter than air, corrosive and explosive. Not a good thing to be feeding into your charger.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is online now
Conduit for 110VAC wires jarcher Gear & Maintenance 7 04-29-2010 12:33 PM
loose electrical conduit in mast Seaquel Announcements and Suggestions Box 1 09-12-2009 05:16 PM
Nice conduit for speaker wires? geary126 Gear & Maintenance 13 02-10-2007 08:15 PM
Holding conduit in place while fastening dnseal Gear & Maintenance 6 11-27-2006 06:45 PM
Conduit in Mast RookieHunter Gear & Maintenance 3 12-11-2002 10:05 PM
