Engine start shuts off chartplotter - Page 2 - SailNet Community
 3Likes
post #11 of 11 Old 02-16-2014
Re: Engine start shuts off chartplotter
I had the same problem. The wiring TO THE PLOTTER was part of the problem due to small wire size. Add in the voltage drop when starting the engine and the voltage to the instruments went low enough to kick it off. Once I upsized the instrument wiring all is fine.
You should add a yearly battery connection PM to your list of routine checks that you do. Lots of good suggestions on this discussion!
scgator2001 is offline
Tags
power drain , starter bank
Chartplotter goes dead when engine is cranked. jefndeb Electrical Systems 5 02-02-2012 01:45 AM
Engine will not start...Starter? tcase10 Electrical Systems 9 06-23-2010 08:47 AM
Engine Start Key bacampbe General Discussion (sailing related) 11 04-05-2010 10:29 PM
20 degree engine start hertfordnc General Discussion (sailing related) 6 01-17-2009 03:58 AM
Engine won't start scurvy Gear & Maintenance 18 10-28-2007 10:56 AM
