Fusing Batteries - Page 2 - SailNet Community
 1Likes
post #11 of 17 Old 04-04-2014
Re: Fusing Batteries
Thanks Maine Sail. On the ground side. In the USE Switch setup, do I run a common negative cable between the house and reserve batteries in addition to a negative run to the Engine ground?
tatracy is offline
post #12 of 17 Old 04-04-2014
Maine Sail's Avatar
Yes house>start>engine neg are all tied together. The only time this would get tricky is if you needed a shunt for the house ban for a battery monitor.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #13 of 17 Old 04-07-2014
Ok, *hopefully* one last question on fusing. I will have 200a terminal fuses on each battery, currently I will have 1AWG wire from house battery to 1/B/2 switch, and 4AWG from backup battery (it's what I have at this point, but will eventually upgrade to 1AWG). Will add echo charger connected at switch 1 & 2 posts per suggestion.
Starter cable will run from Common post on switch, currently 4AWG, also to be upgraded to 1AWG. AM I good to connect the starter cable without an addition fuse, on the assumption that the terminal fuses will protect the circuit from battery to starter in case of a short? I'm struggling with determining which fuse type to use and how to mount if I DO fuse the starter cable.
tatracy is offline
post #14 of 17 Old 04-07-2014
If you are looking to upgrade the 4 gauge wiring, I recommend genuinedealz.com for custom battery cables. The quality and price are both excellent, and I used the savings to upgrade the cable gauge a bit (both batteries now connected to the switch with 2/0)
Note that although your starter is 75A continuous, there will be a surge of higher current to get the engine turning over. This is when voltage drops in the cable can be noticable if the wiring gauge (or connections) are marginal. BTDT.
MarkSF is offline
post #15 of 17 Old 04-10-2014
Thumbs down Re: Fusing Batteries
Bumping back up on inquiry regarding fusing the starter cable at the 1/2/B switch.
tatracy is offline
post #16 of 17 Old 04-10-2014
Maine Sail's Avatar
No need for additional fuse..
______
post #17 of 17 Old 04-11-2014
Thank you all for the help with this
Sent from my iPhone using Tapatalk
tatracy is offline
Tags
fuse battery blue seas
Fusing to the size of the wire.... MedSailor Electrical Systems 6 10-05-2012 03:02 PM
Fusing the wire or the object? SanDiegoChip Electrical Systems 6 06-08-2010 08:48 PM
Fusing Your Batteries - Another Option Maine Sail Electrical Systems 4 05-11-2010 07:55 PM
battery charger fusing jackytdunaway Gear & Maintenance 4 10-04-2007 12:31 AM
aluminum and steel fusing? patrickbwells Gear & Maintenance 8 03-29-2007 07:28 PM
