Corrosion Reference Electrode and User's Guide?? - SailNet Community
post #1 of 6 Old 03-12-2014 Thread Starter
Tundra Down
downeast450's Avatar
Anyone have any experience with this?
by ABYC-Certified Corrosion Experts
Corrosion Reference Electrode Product Specifications
Down
Islander-28, Marshall Sandpiper
downeast450 is offline
post #2 of 6 Old 03-13-2014
Jnoiur Mebemr
StormBay's Avatar
Re: Corrosion Reference Electrode and User's Guide??
Just used it today actually, to check our boat and a friends boat. What do you want to know?
Yu & Frank
StormBay is offline
post #3 of 6 Old 03-13-2014 Thread Starter
Tundra Down
Storm,
I have read what is available, without buying one, on the sellers web site. It seems straight forward. What I would like to do, in addition to evaluating my boat's condition, is get an idea of the condition of a few different harbors here on Mt. Desert Island. My boat suffers zinc loss at markedly different rates depending on where it is tied up. I would like to get something that provides real information on the stray current differences from location to location. Do you think it would be possible to discern relative differences?
Down
post #4 of 6 Old 03-13-2014
Jnoiur Mebemr
StormBay's Avatar
Yes, absolutely... The booklet that it comes with explains the process very well. You can always install a galvanic isolator on your boat if you are worried about stray current form either the marina or another boat.
Yu & Frank
StormBay is offline
post #5 of 6 Old 03-13-2014
mitiempo's Avatar
If you have the AC ground (green wire) connected to the DC negative bus as required by ABYC for safety reasons a galvanic isolator is essential, if not a isolation transformer.
As far as a marina being "hot" it can vary depending which boats are there as they are the major cause.
Brian
mitiempo is online now
post #6 of 6 Old 03-14-2014
Puget Sound Pounder
kellysails's Avatar
Yes, I have one. I log the readings monthly, or try to. I am almost at the point of having a clear coordination between the reading and the health of my anodes. Every boat is different so it takes a while to gain that understanding. I switched from zinc to aluminum anodes and the readings changed quite a bit. No way am I going to dive the hull in this water (PNW) so I find this tool quite handy.
kellysails is offline
Any reviews of Don Guillette's "Sail Trim Chart" or "Sail Trim User's Guide"? 0verdrive Learning to Sail 6 02-07-2015 01:17 PM
Reference Voltage davidpm Gear & Maintenance 14 09-22-2013 08:11 AM
Outboard reference material? utchuckd Gear & Maintenance 4 04-07-2013 09:12 PM
User Guide for Tanzer 7.5 Binabik Gear & Maintenance 1 09-05-2011 01:48 PM
Navtex Nav 7 McMurdo French user guide AMEX Gear & Maintenance 0 04-09-2009 05:36 AM
