How to attach cable to pulpit? - SailNet Community
 1Likes
post #1 of 13 Old 03-16-2014 Thread Starter
Just finished installation of my solar panel. Now I need to route the cable down the frame, then the pulpit stanchion, through the deck and to the controller.
What is the best way to attach it to the stainless steel frame and pulpit? My thought is plastic cable ties. I assume that they will degrade with UV and need to be replaced every few years, and aesthetically they are not perfect.
Are there alternatives?
Thanks.
MastUndSchotbruch is offline
post #2 of 13 Old 03-16-2014
mitiempo's Avatar
Re: How to attach cable to pulpit?
If you are not running the cable inside the pulpit tube - the best solution but hard to accomplish - I would use cable ties. It can look pretty good. Use black ties as they last longer in sunlight as they have more pigment.
Group9 likes this.
Brian
mitiempo is offline
post #3 of 13 Old 03-16-2014 Thread Starter
I considered running the cable in the tubing. But I am afraid the holes required to drill will weaken it which is a safety concern.
Good tip using black ties, in particular since my cable is black! Thanks.
post #4 of 13 Old 03-16-2014
Unless you are using marginal tubing in the first place I can't see it as a problem. If you are worried about strength you could drill it, then sleave where the hole is, but I have never thought it was necessary.
Greg
Stumble is offline
post #5 of 13 Old 03-16-2014
mitiempo's Avatar
I agree, a hole shouldn't weaken the pulpit. To do it neatly the pulpit should be removed to run the cable through the base into the boat. That only leaves one hole visible at the top. A bit more complicated though.
Brian
mitiempo is offline
post #6 of 13 Old 03-16-2014 Thread Starter
I dunno. The tubing is not marginal, it is 1" SS. But the cable by itself has a diameter of 3/8" (waterproof marine cable) and I would not bet my life (which is what you do on safety equipment) on a hole of this size not weakening the structure. In fact, for a proper installation you would not just drill an hole and shove the cable through but use a proper grommet. So we are talking losing AT LEAST a half inch of the 1" tubing.
Yes, I could put a sheathing around it to get back most of the original strength, but come on, all of this for a solar charging cable? Not even talking about the hassle of taking off the pulpit.
No way!
So, we are to black cable ties. Seems like a decent solution. Anything better?
post #7 of 13 Old 03-16-2014
mitiempo's Avatar
Use the cable ties.
Brian
mitiempo is offline
post #8 of 13 Old 03-16-2014
Senior Moment Member
SloopJonB's Avatar
Running the wires through a hole and down inside the tubing is commonplace - I've never heard of a pulpit breaking there.
If you attach it to the outside with tie-wraps you must consider the UV degradation of the wire insulation as well, not just the tie-wraps.
SloopJonB is offline
post #9 of 13 Old 03-16-2014 Thread Starter
Understood.
post #10 of 13 Old 03-17-2014
chucklesR's Avatar
I use cable ties - but - you should use a bit of rubber gromet or other chafe gear of your choice and make sure you cut the tail off and position that tail outboard so it doesn't catch and bite ankles and thighs.
chucklesR is offline
Attach Rope to Becket? Jhiggy Learning to Sail 16 09-13-2013 10:39 PM
Best way to attach keel cable? JMN412 Gear & Maintenance 7 01-24-2013 01:36 PM
Moderator: Why can't I attach pics??!! TakeFive General Discussion (sailing related) 13 09-19-2012 08:40 PM
Windless cable size, cable manufacture and battery type? SanDiegoChip Gear & Maintenance 25 02-19-2010 10:44 AM
How attach reefing lines Kick Gear & Maintenance 44 12-05-2008 09:10 AM
