Circuit Breaker - SailNet Community
 3Likes
post #1 of 16 Old 03-23-2014 Thread Starter
nccouple's Avatar
Circuit Breaker
I'm replacing some wiring and the circuit breaker for my shore power 115 outlets. I found the breaker I need at West Marine but they offer any where from a 5 amp to a 50 amp. Not sure witch one I need. I'm guessing the 30 amp but not sure. I just purchased the boat so I'm unfamiliar with it, also several hours away from it so I cant just go look. Its a Watkins 29 if that helps. Thanks
oursailingadventures.com
nccouple is offline
post #2 of 16 Old 03-23-2014
Re: Circuit Breaker
most likely it's 30 amps, but I'd make sure before doing anything.
Catalina 34
chuck53 is offline
post #3 of 16 Old 03-23-2014
mitiempo's Avatar
Re: Circuit Breaker
I doubt it is anything but 30 amps. Make sure it is a double pole breaker that breaks both hot and neutral wires.
Like this: C-Series White Toggle Circuit Breaker - Double Pole 30 Amp - Blue Sea Systems
Brian
mitiempo is offline
post #4 of 16 Old 03-23-2014
TakeFive's Avatar
Re: Circuit Breaker
You have just one breaker for the whole boat? If so, I would think carefully about allowing all 30 amps to go to AC outlet.
Check the gauge and other specs of the smallest wire in your system. Then do some searching online for what amps it will carry safely. If your outlet is connected with 14 AWG, I would make the breaker 15 amps or less. If you have a panel that splits the current among multiple circuits, you might do 30 amps for the whole boat (master breaker), but then split that into multiple circuits that match the gauge of the wire and rating of the outlets.
I believe that "standard" AC outlets are 15 amp maximum. 20 amp outlets have a "T-shape" hot slot that accommodates the special plugs that 20 amp appliances require.
DISCLAIMER: I am not an electrician. Verify anything I say with a qualified source. (Free Internet advice may be worth less than you pay for it.)
L124C and jraymer like this.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #5 of 16 Old 03-23-2014
mitiempo's Avatar
Re: Circuit Breaker
A proper shore power panel for 30 amp service has a double pole breaker (30 amp) as a main breaker with other breakers for each circuit, usually 15 amps, each wired with 14 gauge wire. The wire from the shore connection to the panel is 10 gauge wire. The panel includes reverse polarity indicator lights. This is a good example of a proper panel.
Many older boats came with just a single double breaker of 30 amps and that should be corrected so any individual circuit cannot draw more than the current it is rated for, typically 15 amps. I would think any good surveyor would consider this a requirement.
jraymer likes this.
Brian
mitiempo is offline
post #6 of 16 Old 03-24-2014 Thread Starter
nccouple's Avatar
Re: Circuit Breaker
Ok I think I was about to screw up. I was getting ready to order the 30 amp. This breaker only controls the 115 shore power outlets. Maybe I should wait till my next trip down and pull it and then order.
nccouple is offline
post #7 of 16 Old 03-24-2014
mitiempo's Avatar
Re: Circuit Breaker
For an individual circuit you want a 15 amp breaker. Blue Seas model # 7210 or similar.
A-Series White Toggle Circuit Breaker - Single Pole 15A - Blue Sea Systems
Brian
mitiempo is offline
post #8 of 16 Old 03-24-2014
Dirt Free
boatpoker's Avatar
Re: Circuit Breaker
You have two circuit breakers but no 30amp main ????
Is the polarity indicator wired across both circuits ?
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #9 of 16 Old 03-24-2014
mitiempo's Avatar
Re: Circuit Breaker
I'm assuming the double pole main is above the reverse polarity light. There certainly has to be one.
Brian
mitiempo is offline
post #10 of 16 Old 03-24-2014
Dirt Free
boatpoker's Avatar
Re: Circuit Breaker
I'd hope so but in my experience I wouldn't bet on it
I can do that
- wg
Anyone have any feedback on this? - circuit breaker wiring design, relays, dump load Bene505 Electrical Systems 13 04-22-2011 10:45 PM
Need circuit breaker panel inshallamiami Gear & Maintenance 10 03-25-2008 03:13 PM
Circuit Breaker drynoc Gear & Maintenance 8 11-14-2007 09:15 AM
Circuit Breaker Replacement Tom Wood Gear and Maintenance Articles 0 02-05-2002 07:00 PM
