DC Voltage -- Negative Bus to Ground - SailNet Community
post #1 of 3 Old 03-31-2014 Thread Starter
Am checking my DC circuits and noticed that the voltage between the negative bus and the hull ground ranges from 1-12 volts based on DC load. Makes sense to some extent I guess, but the thought of loading 1-12 volts constantly into my steel hull through the connection between the negative and ground bus would seem to be a problem. Or maybe not!!
kaakre is offline
post #2 of 3 Old 03-31-2014
Maine Sail's Avatar
Re: DC Voltage -- Negative Bus to Ground
There should be no current on your ships "ground" and your ships ground should NOT be a DC neg return path...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 3 Old 04-18-2014
Coquina's Avatar
This sounds bad on a few levels.
If you have a floating ground DC system, there should be exactly 0 volts between the DC system at ANY point and the steel hull.
If you have a grounded DC system, the DC ground bus should ground to the hull at ONE point only. There should ALSO only be 0 volts between any negative wire and the hull*.
I can't diagnose this over teh interwebs, but you have an issue that really needs looking into.
* to be accurate, there could be a little voltage drop between a load and where the negative wire run gets back to the panel ground.
Joe Della Barba
Coquina
C&C 35 MK I
Coquina is offline
Adding a negative ground buss rhr1956 Gear & Maintenance 2 04-29-2013 12:51 PM
Connection strap from meter shunt to negative bus Rusty123 Electrical Systems 0 04-18-2013 11:22 PM
Help with DC negative question josrulz Electrical Systems 11 03-27-2012 11:34 AM
Negative Reputation? arf145 Announcements and Suggestions Box 22 04-07-2011 08:29 AM
DC Ground vs. Negative Return dougshome Gear & Maintenance 6 07-23-2003 08:54 AM
