Battery Help - SailNet Community
post #1 of 6 Old 04-12-2014 Thread Starter
hillenme's Avatar
Battery Help
Made a huge amateur mistake last weekend... When reconnecting batteries last weekend I accidently reversed polarity on one of them and then turned the switch on. Needless to say wasn't pretty. The terminals on the both batteries even the one hooked up correct melted. The breaker on the battery switch did not trip. I took both batteries off and bought new ones. Only had one in stock so I only hooked that one up today after replacing the lugs since they soldered to the old battery. All breakers on the panel were off and all components appear to be okay with some interesting exceptions... I only have one batt hooked up now, the number two. When I select two or all on the batt switch everything works except the stereo which only works with selector on all despite having only one batt on the boat. How much damage have I likely done? Do I only need a new switch? What about starting system? It's on hard so I didn't try and start it but I do get low oil press light and alarm with ignition on.
hillenme is offline
post #2 of 6 Old 04-13-2014
redline's Avatar
Re: Battery Help
Could it be that the stereo is wired direct to the B1 side of the switch, or to B1 directly? Probably done to preserve the tuner memories when the switch is off. Not ideal but OK as long as it's fused near the battery. Follow the wiring.
If that's the case, there's probably nothing wrong with your switch.
Sent from my iPad using Tapatalk
Norman
s/y "Redline"
1998 Jeanneau SO45.2
redline is offline
post #3 of 6 Old 04-13-2014 Thread Starter
hillenme's Avatar
No, it's wired same as all other components.
hillenme is offline
post #4 of 6 Old 04-13-2014
Learning the HARD way...
eherlihy's Avatar
Re: Battery Help
I believe recline has it right. More than likely that the stereo memory is wired (either at the battery, or the switch) to the other battery circuit.
Sent from my VS930 4G using Forum Fiend v1.1.3.
eherlihy is offline
post #5 of 6 Old 04-13-2014
eherlihy's Avatar
Re: Battery Help
(friggin' cellphone) I meant redline
eherlihy is offline
post #6 of 6 Old 04-13-2014
redline's Avatar
Re: Battery Help
Don't knock autocorrect - that's the only reason I ever get called Normal.
Norman
Norman
s/y "Redline"
redline is offline
Battery Chargers for Multiple Battery Banks btrayfors Electrical Systems 5 11-15-2009 11:57 AM
New Battery charger (unplugged) causes spark on battery post!! Northeaster Gear & Maintenance 15 11-17-2008 08:30 PM
Adding second battery; battery location zoom555 Gear & Maintenance 4 01-24-2008 08:46 PM
Sizing a Battery Charger for Windlass Battery btrayfors Gear & Maintenance 9 04-11-2007 12:43 AM
Starting Battery vs. House Battery GarrettK Gear & Maintenance 18 10-26-2004 10:58 AM
