eliminated engine...wheres my negative? jajaja - SailNet Community
 24Likes
post #1 of 58 Old 05-18-2014 Thread Starter
christian.hess's Avatar
Guys this might seem foolish to ask but Im going down to the boat tomorrow on my ongoing project...and time is of the essence...
one thing I havent tackled yet(on my projects) is my electrical system
this is whats left of my engine/electric room
last time around I was trying to test out my system and hooking up my battery and got no juice no matter what I did to my panel
I do get juice to the bus bars on each side of this pic...not seen though
my newb question is Im pretty sure the engine block(old palmer) was used as a common ground
so what would be the simplest way of getting a common ground now, going back to battery terminal? ground plate in bilge? what?
...at this point my main goal is to eliminate all ENGINE related wiring which is the big mess you see here...the panel has the old style breakers with fuses...
Im quite limited in boat eletrical systems...I can get my way around motorcyle looms and stuff but never have really tackled a full "rewire" job on any of my boats...
any and all help appreciated...
thanks
christian
ps. if it helps any I have no external grounding strap or copper plate, and none of my thruhulls are bonded
I do however have one aft keel bolt that has a wire to it...I do not know if it is a lightning ground or what...
my keel is iron...
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #2 of 58 Old 05-18-2014
Stu Jackson's Avatar
Re: eliminated engine...wheres my negative? jajaja
Yes.
Done.
Don't use anything else.
It always was your electrical ground which was then, itself, grounded to the engine.
christian.hess likes this.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
The Following User Says Thank You to Stu Jackson For This Useful Post:
christian.hess (05-18-2014)
post #3 of 58 Old 05-18-2014
mitiempo's Avatar
What Stu said - he beat me to it.
Brian
mitiempo is offline
post #4 of 58 Old 05-18-2014
Asleep at the wheel
jimgo's Avatar
Christian, as an aside, is your shaft log made of bronze? If so, you may want to consider using that as a ground.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #5 of 58 Old 05-18-2014 Thread Starter
awesome thats what I wanted to hear
first thing is first eliminate the engine harness crap...
thanks guys
post #6 of 58 Old 05-18-2014 Thread Starter
I think it is...jejeje
post #7 of 58 Old 05-18-2014 Thread Starter
I want this as KISS as possible, if possible!
post #8 of 58 Old 05-18-2014
Once known as Hartley18
Classic30's Avatar
Dock
Christian, if you want KISS as possible and you don't mind having wires in the engine bay, to save yourself much effort and make it easier for someone if (when!) the engine goes back in, I'd suggest:
Instead of going all the way back to the battery terminal like Stu suggests, just mount a plain old bolt somewhere convenient close to where the original grounding point was for the engine and hook the old ground wire(s) up to that. Google "grounding post" and use one of those if you want to do it properly.
You can also then easily bond from there to the shaft log if you want and it will be clear to anyone looking at it later exactly how it's all connected...
Classic30 is offline
The Following User Says Thank You to Classic30 For This Useful Post:
christian.hess (05-19-2014)
post #9 of 58 Old 05-19-2014
Second what Classic suggests... Wrap the old engine wiring up neatly and leave in place...If you want to get fancy use a negative bus bar instead of the simple bolt...
The trick to electrical work is to never let the magic smoke out...if you see smoke you can be pretty sure that something electrical is about to quit working...
Bob142
Desolation Sound
Maple Leaf 48
Any storm in a port...
Bob142 is offline
post #10 of 58 Old 05-19-2014 Thread Starter
can you help me out here(I appreciate it)
so the engine block was the common ground...was that then grounded to something else?
Ill be honest I havent looked for a ground to hull scenario on this boat...I dont see one except for that 1 bolt in the aft bilge that does have a black wire running to it...
ill need to chase that to see if it does happen to be a "post"
its quite possible the reason I got no voltages at the panel was cause all the grounds were lose and not together tied to anything
Im not a fan of bonding to the sea if you will
I dont want my thruhulls and whatnot getting current through them and whatnot and I didnt want this thread to become a lightning or no lightning hit thread
im not in a marina so im not in hot water if you will but all my boats have never had bonded thruhulls and chainplates and such
thanks
illlook up grounding post
Help with DC negative question josrulz Electrical Systems 11 03-27-2012 12:34 PM
seaclear wheres mapcal? scosch Gear & Maintenance 5 09-26-2009 12:03 AM
So wheres the Beezer Stillraining General Discussion (sailing related) 16 06-11-2008 09:52 PM
Wheres My Rudder? scott_sale Seamanship & Navigation 51 03-07-2008 04:44 PM
Wheres your eden? codmander General Discussion (sailing related) 23 02-29-2008 12:27 PM
