15 AH Deep cycle - SailNet Community
post #1 of 5 Old 06-12-2014 Thread Starter
15 AH Deep cycle
A friend has a boat with minimal power demand -- probably less than 3.3 amps (running lights and a Raymarine 435 chartplotter) for no more than two hours. If he had a 15AH battery, this load would only draw the battery down 40%. He keeps his boat on a mooring and schleps the battery ashore to recharge so lighter is better. Any ideas on what to use? Wheel chair battery?
Hudsonian is offline
post #2 of 5 Old 06-12-2014
Re: 15 AH Deep cycle
Motorcycle not wheel chair. They are even lighter. Down around 12-15lbs for that size. But he would probably do better to buy a cheap solar panel to recharge the battery in place. They are available from WM for about $40.
Greg
Stumble is offline
post #3 of 5 Old 06-12-2014
Stu Jackson's Avatar
I used to schlep, too, with our Catalina 22. 1983 to 1987.
These days, get a solar panel and controller. Question answered.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #4 of 5 Old 06-14-2014
JimsCAL's Avatar
A solar panel is definitely the way to go. A 10-20 watt panel plus a controller can be found for $100 or so today.
JimsCAL is offline
post #5 of 5 Old 06-14-2014
islander bahama 24
newhaul's Avatar
The size of solar panel would depend on the needed charging time and with solar on the boat he could use a considerably larger battery and keep the discharge well above the recommended minimum of half
Illegitimus Non Tatum Carborundum.
newhaul is offline
Are All Deep Cycle Batteries Alike? chuck711 Gear & Maintenance 24 09-15-2015 03:48 PM
Maint. charger for deep cycle Survivor Gear & Maintenance 5 06-25-2010 12:00 AM
CD Player and a Deep Cycle Battery mountforever Gear & Maintenance 5 09-14-2009 12:07 AM
Starting battery and deep cycle - charging ChesapeakeCal29 Electrical Systems 16 08-18-2009 10:17 PM
Using a deep cycle battery for starting? MedSailor Electrical Systems 9 07-11-2009 05:54 PM
