Wire chase source? - SailNet Community
post #1 of 5 Old 07-03-2014 Thread Starter
Wire chase source?
I'm re-wiring my restoration-project Balboa 26 and in several places I need to run wires along bulkheads or on the curvilinear walls of the cabin shell. I'd like to hide them in (what on land is called) a chase - a rigid tube that can be fastened to a wall with adhesives or screws within which the wires can be run. However, the chases I can find are unable to handle the curving wall surface of a cabin. Any advice on sources? Thanks!
Toad Away! is offline
post #2 of 5 Old 07-03-2014
Once known as Hartley18
Classic30's Avatar
Dock
Re: Wire chase source?
I'd suggest using PVC Duct instead. It has a removable lid to hide both the wires and the screws and is flexible enough to take a curve... it's easier to install the wiring in also.
This stuff:
EDIT: ..and welcome to Sailnet!
Classic30 is offline
post #3 of 5 Old 07-04-2014
CapnChuck's Avatar
You can use typical pvc pipe. If the size is too large to bend along the hull, just heat it a bit and bend to fit. I have done this often to install wiring. Chuck
Our Blogs
CapnChuck is offline
post #4 of 5 Old 07-06-2014
Stu Jackson's Avatar
Look on an online chandlery, like West Marine or Defender. McMaster Carr is also good for that kind of thing and many other.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #5 of 5 Old 07-07-2014
For places with access I like the paduit wireway for neatness. http://www.grainger.com/product/PANDUIT-Wire-Duct-Cover-3EYE1?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/3EXX1_AS01?$smthumb$
For runs behind under deck etc I use non metallic conduit from the electrical supply store. You can get flexible or rigid versions. Most boatbuilders just seem to use PVC pipe.
Colin A
Work for Bass Products
colinsim.com (my personal site)
Colin A is offline
tips needed to chase dc short lajimo Electrical Systems 23 07-04-2013 04:13 PM
Two ladies need chase boat for SUP in NC Danasailor Announcements and Suggestions Box 0 06-05-2013 08:21 AM
Tartan 30 Wire Chase eko_eko Electrical Systems 2 04-30-2013 10:24 AM
Source for AC wire connectors? floatsome Electrical Systems 6 04-08-2009 07:07 AM
Source for 110v Marine Grade Wire JimMcGee Electrical Systems 7 01-27-2009 02:04 PM
