Rewiring US Yacht 25 - SailNet Community
 3Likes
post #1 of 12 Old 07-18-2014 Thread Starter
budvar's Avatar
I'd like to rewire my US Yacht 25 (1982). Have read up and down this forum, studied diagrams. Not an electrician, but have purchased (and read) the two boating electrical books most quoted here.
At the risk of beating an old horse to death, I will give an attempt at a wiring diagram. History: US Yacht 25. Wires going everywhere and to nowhere. + and - wires going across from each other on same bus.
9.9 OB motor. Have already rewired mast and replaced mast lights with LED's.
Without going into too much detail regarding wire size, just wondering if I have the basics right. Plan on having 2 batteries, and using the house as detailed by Mainsail et al as the full time start/house battery.
Thanks for your input.
Chris
Tri-Cities, Wa.
Chris
US Yacht 25 "Chinook"
Kennewick, Wa.
budvar is offline
post #2 of 12 Old 07-18-2014
mitiempo's Avatar
Re: Rewiring US Yacht 25
Pretty basic diagram but it looks ok. How will you be charging the batteries?
Brian
mitiempo is offline
post #3 of 12 Old 07-19-2014 Thread Starter
budvar's Avatar
Thank You Brian,
That was my next question. Would it be easier and less complicated to get a battery charger that monitors both batteries? Or go with an ACR?
I didn't want to get too detailed regarding wire size just yet. Just wanted to make sure I had the right idea.
I've been carefully collecting and using appropriate tools....wire cutter and crimper, heat gun. Just received a battery crimper. I have a wife, you should have seen her response to me purchasing a $180 tool. Have new Bus's, and a Blue Sea electrical panel. Still need a charger, and of course, appropriate sized wire and lugs.
Thanks!
Chris
Kennewick, Wa.
budvar is offline
post #4 of 12 Old 07-19-2014
mitiempo's Avatar
If the outboard charges I would get an ACR. If you will be adding solar the ACR makes sense as well. If the AC charger will be the only method of charging most good marine chargers will charge at least 2 banks.
Brian
mitiempo is offline
The Following User Says Thank You to mitiempo For This Useful Post:
budvar (07-20-2014)
post #5 of 12 Old 07-20-2014 Thread Starter
budvar's Avatar
Appreciated, thanks!
Chris
Kennewick, Wa.
budvar is offline
post #6 of 12 Old 10-26-2014 Thread Starter
budvar's Avatar
Ok. Have built a battery box and rewired (using Main Sail's recommended tools and techniques) to 12B0 switch and then + and - busbars.
Question: I have a 10 bank Blue Sea electrical panel. However, I get confused (often). Esp. where it comes to wiring multiple circuits to the panel. The provided diagram recommends connecting + circuit wires to the panel. Should I also connect each - circuit wire to the electrical panel, or to the large - bus I have installed nearby. For the record, I ran the - bus on 4awg right after the battery.
Thanks again!
Chris
Chinook
US Yacht 25
Kennewick, Wa.
Chris
Kennewick, Wa.
budvar is offline
post #7 of 12 Old 10-26-2014
mitiempo's Avatar
I use a bus for the negative wires. It keeps the panel neater.
Brian
mitiempo is offline
budvar (10-26-2014)
post #8 of 12 Old 10-26-2014 Thread Starter
budvar's Avatar
Thanks Brian. I just wanted to make sure wasn't missing something. The - bus has 20 #10's. I'm sure wiring the - to the - bus was obvious to most people, just not myself. And yes, it will definitely make things neater and less clutter behind the panel.
FYI. Wife and I are not too far from you. We're visiting Anacortes/Bellingham in two weeks. We're getting closer to retirement and looking for a new place to call home.
Thanks again,
Chris
Chris
Kennewick, Wa.
budvar is offline
post #9 of 12 Old 02-27-2015 Thread Starter
budvar's Avatar
Thanks to everyone on Sail.net and definitely Main Sail.
I completed a much needed rewiring, starting with a new battery box (old one was plastic and had too much freedom of movement!). While I was in epoxy mode, added a bulkhead and gained some new storage space.
As you can see, the wiring wasn't exactly to the ABYC Standards. Wire nuts. Some wires leading to nowhere. Even bus's with both positive and negative wires on the same terminal. Automotive battery lugs and cable. I'll stop here, but there were a few more surprises along the way.
Chris
Kennewick, Wa.
budvar is offline
post #10 of 12 Old 02-27-2015 Thread Starter
budvar's Avatar
I can't thank Main Sail enough for his knowledge, and illustrations on how to do things the right way. Now I have some new skills, and several new tools (the right ones, at that).
Tried my best to get it right. Have a 30 amp breaker right after the battery, and again after the +bus leading to the OB motor. 4 ga cable runs from the battery thru the + bus, to the panel, and again 4 ga to the neg bus and back to the battery.
This was a major project (for me, anyway). Now on to the fun...installing the stereo.
SHNOOL likes this.
Chris
Kennewick, Wa.
budvar is offline
Link 20 rewiring chris_gee Electrical Systems 11 09-19-2009 05:02 PM
Link 20 rewiring chris_gee Gear & Maintenance 0 09-17-2009 03:39 AM
Rewiring my Catalina 25 SpcAlan1 Electrical Systems 12 09-08-2009 11:16 PM
Rewiring 12 for three batteries witzgall Gear & Maintenance 12 12-09-2007 10:28 AM
Rewiring the Mast Duke 7184 Gear & Maintenance 13 11-27-2006 07:54 PM
