Electrical System Update - Page 2 - SailNet Community
 1Likes
post #11 of 12 Old 08-15-2014
Senior Pirate
TropicCat's Avatar
Re: Electrical System Update
Originally Posted by SVAuspicious View Post
In the case of battery capacity more IS better.
Sure ... Agreed ... but only if you can charge it with a 14 hp engine in a couple of hours.
Tropic Cat
TropicCat is offline
post #12 of 12 Old 08-15-2014
mitiempo's Avatar
Just because you have more battery capacity doesn't mean that you use more AH. It is not any tougher to put 100 AH into a 900 AH bank than a bank half the size. The larger the battery bank the higher the SOC they go down to with a given load. Because of this they will last longer. Due to Puekert there are gains in bank size beyond the 20 hour rating as well with a given load.
A 100 AH battery with a 5 amp load is 100 AH. A 200 AH bank with the same load is somewhat more than 200 AH.
Brian
mitiempo is offline
Update on NYS Canal System smurphny General Discussion (sailing related) 4 05-06-2014 08:11 PM
Venture 17 Electrical System SailingV17 Electronics 2 06-09-2013 03:55 PM
Updating electrical system dszerlag Electrical Systems 8 12-10-2012 05:31 PM
Help With New Electrical System Oldsoul Electrical Systems 44 02-03-2012 10:09 AM
Link Pro & Electrical update Stillraining Electrical Systems 1 02-10-2010 01:28 PM
