Zinc Consumption question - Page 2 - SailNet Community
post #11 of 15 Old 08-14-2014
Cruising at a snail pace
Re: Zinc Consumption question
Originally Posted by Fstbttms View Post
Huh?
funny you understood it pretty good on the other forum
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
post #12 of 15 Old 08-14-2014
I don't discuss my member
Fstbttms's Avatar
I'm pretty sure neither you or anybody else made that statement on the other forum. But since you've made it here and it's about as clear as mud, maybe you can enlighten me as to why electrical current would find it "so much easier to go to the zinc on the prop" as opposed to the shaft.
Fstbttms is offline
post #13 of 15 Old 08-14-2014
not going to waste time arguing with you, after all you know what I say everywhere better than I do
Don0190 is offline
post #14 of 15 Old 08-14-2014
Fstbttms's Avatar
Jeezus, not arguing. Just do not understand your logic. Was hoping you could explain it. I guess that's asking too much.
BTW- you presume that I know who you are on the other forum. I do not.
Fstbttms is offline
post #15 of 15 Old 08-14-2014
Nearly an Old Salt
Originally Posted by ereiss View Post
I have shaft zincs (2) as well as a zinc at the end of my maxprop. I have started to also put a large zinc over the side when on the mooring connected to the grounded system.
I noted that the zincs on the shaft are lasting much longer with this latest change but the prop zinc still disappeared quickly.
Is the prop zinc more active, or its position unique that causes it go faster than the zincs on the prop? My goal was to have the prop zinc last all season so I didn't need to have a diver replace it mid-season.
Thanks for any insights.
I suspect the primary reason is that the whatver metal the zinc on the end of the Maxprop is protecting, is not that well electrically connected to your grounding/bonding system. There must be a good electrical connection between the zinc over the side and the metal you are trying to protect
goboatingnow is offline
Tags
zinc
Diesel consumption. flyingwelshman General Discussion (sailing related) 17 07-12-2012 07:25 PM
Fuel consumption question tireman Gear & Maintenance 15 05-18-2011 12:18 PM
beta marine BD722 newbie question re-coolant/zinc anode! jaybeegee Diesel 2 04-21-2011 07:21 AM
Another zinc question sailak Gear & Maintenance 9 05-29-2009 07:02 PM
a simple zinc question... sailhog Gear & Maintenance 53 07-13-2007 10:30 PM
