Portable Generator - Page 2 - SailNet Community
 7Likes
post #11 of 27 Old 08-27-2014
Re: Portable Generator
But, seriously, running one of these freakin' things while UNDER SAIL ???
If I have to share the anchorage with that, I'd just as soon he run the generator while he's under sail so maybe I don't have to endure his generator whilst sharing the anchorage, yes?
jimrafford likes this.
Multihullgirl is offline
post #12 of 27 Old 08-27-2014
Originally Posted by xort View Post
No indication as to the size of the charger. I can just barely run 2 40 amp chargers at full load. The honda is NOT 2000 watts, it is about 1400 if you get a good one.
Yup, that information could be useful... :-)
Assuming a single 50 amp charger, the Honda 2000 should certainly be up to the task. There's a thread now on this subject over on Cruising Anarchy, and Evans Starzinger finds his EU1000 to be adequate for use with a Sterling charger, but I don't know how he does it... :-)
I have a Honda 1000 aboard for emergency use, but I'm really starting to wonder why I bother. I have NEVER had to use it aboard the boat, in fact the only use it has ever seen was at my home in the aftermath of Hurricane Sandy, when my neighborhood was without power for 20 days. If I am gonna bother with carrying one of these things, I really should have gone with the 2000. But that additional size on a boat as small as mine, it makes all the difference, as I just happen to have a perfect spot the 1000 fits very neatly into...
In testing, I've tried to get the Honda to run my older Heart Interface Freedom 1000 inverter/charger, and it really struggles. The initial surge will shut down the generator immediately. Even after dialing down the 'Power Share' setting to a very modest percentage, it barely handles it (I'm guessing my older style Heart Interface is a pretty inefficient unit, by today's standards) The only way I could get it to work, was to run it for a bit using the 12V cords to the battery, in an attempt to get them 'up to speed', so to speak... But, having to use that thing as a routine means of charging, I think I'd probably quit sailing, instead...
but, as long as I have the damn thing, if anyone has any magic bullet solutions, I'm all ears... :-) If I didn't need it this summer, however, I seriously doubt I ever will, and I think the smartest thing for me to do is to put the thing on eBay...
JonEisberg is offline
post #13 of 27 Old 08-27-2014
islander bahama 24
newhaul's Avatar
Yeah, running that thing to charge via DC @ 8 amps, that's efficient, alright... :-)
Well, we don't know what sort of boat we have here, or the type of sailing/cruising being done, so... But I have to charge my batteries just like anyone else, just seems to me there are better options...
Also puts out 25amps at 120 volts will run a 50 amp output battery charger still Iwould rather use solar for battery charging
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #14 of 27 Old 08-27-2014
??? You talkin' about the Honda EU2000i ???
It is rated at 2000 watts (16.7 amps @ 120VAC) and it will run a 75 amp battery charger just fine.
No argument about the preference for solar power....if you've got the real estate for the panels and a good MPPT controller, that's surely the way to go. No messy stuff, no additional cost, no noise, no maintenance and at least a 20-year service life. What's not to like about that?
Bill
btrayfors is offline
post #15 of 27 Old 08-27-2014
bljones's Avatar
Here's the win/win, IMO. Instead of spending $1100+ for the honda genny, spend $400 on 120 watts of solar panels, and $600 on a Champion generator.
http://www.amazon.com/Champion-Equipment-73536i-Generator-Compliant/dp/B0041K09D8
Your solar will keep your batteries chharged up silently and handle all of your regular onboard needs- computers, lighting, etc. Your generator is used infrequently, to run tools, etc, when needed. Champion generators are the Samsung TV or the Hyundai automobile of the generator world- damn near as good as the honda benchmark with a better ROI on your money. ... money that you have put into solar panels so you don't have to run the generator as often, which will increase longevity, thus increasing ROI...
newhaul likes this.
It's 5 o'clock somewhere:
bljones is offline
post #16 of 27 Old 08-27-2014
islander bahama 24
newhaul's Avatar
Bill
Actually bil I was referring to the 2500 watt unit from harbor freight Inverter Generator - 4.7HP, 2500W Inverter Generator rob
newhaul is offline
post #17 of 27 Old 08-28-2014
mitiempo's Avatar
Actually it is slightly less than 21 amps @ 120 volts.
Brian
mitiempo is online now
post #18 of 27 Old 09-01-2014
Stu Jackson's Avatar
Ach, here we go yet again.
The 1000 generators will charge a house bank ONLY if there's a properly sized shorepower charger installed. This will depend on how big your house bank is and what it is: i.e., AGM or FLA. If you have a 10A shorepower charger, almost nothing will help, except being plugged in at a dock!
If you have a BIG house bank and a MEASLY charger, no generator will help.
The 2000 will be big enough to run your water heater, the 1000 won't. Why? 'Cuz the 1500 watt heater element is too big for the 1000 to handle.
Almost ALL Harbor Freight electrical stuff is TRASH.
Go from there, 'cuz that's the summary from the past 20years of experience.
Oh, yeah, there's the whole "companion" vs "regular" Honda discussion.
Look at the Honda website and find out the simple answer: the Companion model has the 30A output built in for a simple connection to your shorepower inlet.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #19 of 27 Old 09-01-2014
old guy :)
rikhall's Avatar
Irwin Citation 34
Honda EU2000i ($999.99 with free shipping)
New solar panel
We love the combination. Just did 36 days down the coast of Maine and back. And I never worried about the batteries. On occasion (three wet storm days in a row) we even hit the breaker for the Hot Water heater for HOT showers.
Rik and Linda
Irwin Citation 34
Mystery
rikhall is offline
post #20 of 27 Old 09-05-2014
Where you usually sail has a huge impact on the practicality of solar power to charge batteries. In the Pacific Northwest, solar is useful for at most 3 months of the year --- while the sailing season is 12 months. Hence the practicality of a generator and a 3-Stage Smart charger.
rikhall likes this.
northwestsailor is offline
Stowing Portable Gasoline Generator Coquillage General Discussion (sailing related) 4 02-01-2010 07:24 PM
Portable Generator Snboard976 Gear & Maintenance 13 02-24-2009 03:25 PM
Portable Generator vs Genset dougshipl Gear & Maintenance 109 06-07-2008 12:36 PM
New Portable Generator bushrat Gear & Maintenance 22 04-01-2008 05:20 PM
Portable Generator question SVGratitude Cruising & Liveaboard Forum 35 01-04-2008 09:14 PM
