Alternator for Charging Batteries - SailNet Community
 1Likes
  • 1 Post By eherlihy
post #1 of 7 Old 07-24-2015 Thread Starter
I will be motoring quite a bit in the not too distant future. Currently, there is an internal voltage regulator on the alternator. When primarily motoring, will this alternator/voltage regulator combination over charge the batteries and cause shortened life? Should the internal voltage regulator be replaced with and external regulator like a Balmar?
Thanks for the help in advance.
gbgreen59 is offline
post #2 of 7 Old 07-24-2015
Re: Alternator for Charging Batteries
It shouldn't if the Voltage regulator is working properly.
tempest is offline
post #3 of 7 Old 07-24-2015
Learning the HARD way...
eherlihy's Avatar
While Tempest is correct, the type of batteries that you yous has some bearing on this.
Assuming that you have flooded lead acid batteries, the charge profile from a "dumb" regulator should be fine... Upgrading to an external regulator could help you maximize the state of charge that you can bring the batteries to with a shorter period of time spent running the motor. This seems to be the opposite of your situation.
However, if you have upgraded to AGM, Gell, or Lithium, then you will want to upgrade the regulator.
gbgreen59 likes this.
eherlihy is offline
The Following User Says Thank You to eherlihy For This Useful Post:
gbgreen59 (07-24-2015)
post #4 of 7 Old 07-24-2015 Thread Starter
Thanks, this is very useful. I have lead acid batteries. So, guess I'll be good then.
post #5 of 7 Old 07-24-2015
Maine Sail's Avatar
All batteries AGM, GEL and flooded are "lead acid"..
What brand of battery?
What model battery?
What brand alternator?
What is the voltage set point of your internal regulator?
How many hours at a time will you run before discharging again?
Generally speaking you should be fine but this will depend upon your internal regulator and battery bank and how long the runs are.
Some internal regulators are set for 15.0V and some for 13.8V and some batteries charge at 14.1V and some can charge regularly as high as 14.8V.....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #6 of 7 Old 07-24-2015 Thread Starter
What model battery?
Thanks for stepping in on this topic. I'll get the information on the batteries and alternator. The batteries are 85Ah. We'll be motoring all day for many days without sailing. Will be anchored at night.
post #7 of 7 Old 07-25-2015
Stu Jackson's Avatar
Overcharging with Combiners or ACRs The MYTH:
Overcharging Batteries with a Combiner or ACR
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
The Following User Says Thank You to Stu Jackson For This Useful Post:
gbgreen59 (07-27-2015)
Charging batteries Alternator Vs Generator deandavis1 Electrical Systems 25 11-26-2010 11:28 PM
Batteries not charging Crunchtime Gear & Maintenance 5 09-06-2008 03:40 PM
Charging batteries wchevron Gear & Maintenance 19 03-02-2008 10:21 AM
Batteries & Charging capedory30 General Discussion (sailing related) 2 04-27-2001 04:05 PM
Charging Batteries navtron Gear & Maintenance 1 01-12-2001 05:57 AM
