Hi,
The batteries on my boat are dead and it's time to replace them. There are currently three group 27 Interstate batteries. They are wired in two banks. Batt 1 is bank 1 on my OFF 1 2 Both switch and batt 2 and 3 are connected in parallel and are switch 2 on the switch. The batteries are mounted in a small tray, about 1/2" high, and securely strapped down. The base of the tray is exactly 12 1/4" long and 7 1/8" wide. The height is not a concern as there is no box, just the tray the batteries sit in and the strap to hold them down. There is no more room to add additional batteries and I don't care to add more batts.
My electrical needs are pretty simple. The boat is on a mooring, no shore power. Recharging is by engine alternator. Electrical power is used for instruments (plotter, speed, depth, VHF), etc. I do have 12V refrigeration but that is only used on weekend or longer trips. We do occasionally spend a night or two at anchor, so cabin lights (mostly LED) are used for a few hours and laptops and phones get charged. I would never need battery power to last more than 2 days, as I would either be in a marina or sailing somewhere else.
Anyway, the simplest thing to do would be to buy 3 new group 27 deep cycle batteries, like from Trojan, Crown, etc. However, if I want more power, can i install 1 12V battery for the engine starting and 2 6V batteries for the house bank? Note that the batteries need to be charged by the engine alternator. Will the 12V engine battery and 2 6V batteries (wired in serial for 12V) be charged correctly from alternator?
Thanks for any info you have.
Barry
Barry
