Old 08-05-2008
s/v Black Dog
craigm7493 is on a distinguished road
Honda 2000
I am thinking of purchasing a Honda 2000 or like model to use a a backup charging system for my house batteries. How would I hook this unit up to my 30 amp shore power?
Old 08-05-2008
Vasco's Avatar
Warm Weather Sailor
Vasco is on a distinguished road
with a short extension cord and a 15/30 amp cheater. very easy.
Rick I
Toronto in summer, Bahamas in winter.
Old 08-05-2008
Dunlookn has a little shameless behaviour in the past
Get A Better Deal
I was at my local Camping World a few days ago. They are selling the 2000 with a $ 100.00 gas gift card. That is the best deal I have ever seen on this product.
Don't own stock...but this is the best deal I've seen.
Old 09-03-2008
dsarin is on a distinguished road
We bought our Honda eu2000i two and a half years ago at haysequipment.com for $850 shipped, the best deal we could find at the time. We hook it up to our 30 amp shore power receptical with a short extension cord and a 30amp to 110v pigtail, about 18" in length purchased from West Marine.
Old 09-18-2008
aa3jy is on a distinguished road
Bought the 2000ei about 3 months ago..had a problem starting after only running for about an hour. Went to the local dealer to have it fixed under warranty..dealer said it was bad gas and not under warranty.. I complained to Honda..they had it repaired(new carb)under warranty..Went back to the local dealer to pick up the generator..service manager was 'pissed' that Honda had approved it for repair under warranty..said it made him look like a "fool" and that he was following their policy of not repairing under their written policy of no warranty for bad gas.
Surprising I was using the same gas for all my other power equipment to include a 15yr old Honda 1000 and they all worked fine.....
Old 09-18-2008
Vitesse473's Avatar
Wannabe Sailing Bum
Vitesse473 is on a distinguished road
Craig,7493 - I am looking to do the exact same thing. I have a 690ah battery bank (6-6volts) and my 60amp alternator likely won't cut it for charging them up in a reasonable amount of time. I was going to have a larger Balmar alternator put on, but I'm out of time before I leave for San Diego (then on to Cabo). I've added some electronics and radar, so I plan to use the 3 day trip from SF to San Diego to really determine what my actual draw will be with the iron genny in the off position for several days. I added a Link 20 battery monitor which should give me the actuals I need to determine if bringing along a Honda 2000 will be needed.
Please post your experience if you get one. I'll do the same.
Old 09-18-2008
camaraderie's Avatar
moderate?
Vitesse...what size charger do you have? the Honda won't do it alone.
With 700ah's you will need to replace 350ah's at 50% depleted. If they are flooded 6V rather than AGM...you can put 100-140amps in during bulk charging. That is pushing the Honda's output limit and there will also be conversion losses...suggest you get something in the 100amp range as running the Honda for 3 hours will bring them most of the way back up.
Old 09-19-2008
Vitesse473's Avatar
Wannabe Sailing Bum
The batteries are 6volt wet cell 232ah, so I'll have a total of 696ah (345ah usable). The charger is a Magnum ME2000, which has a 2000watt inverter and 100amp charger. When the batts reach 50% depleted, I had planned to run the engine while under way, and before we reach our destination. I had planned for 4hrs of engine run time per day for the 6 days we are under way. 60amp alternator (85% efficiency is 51amps @ 2800rpm), so 51amps*4=204amps. That leaves me 37amps shy of the 85% full mark, and 104amps shy of the 100% mark. Honda states max output of 16.7amps, so what's the actual? Is it realistic to think running it for 4hrs while on the hook will get me another 48amps into the bank? Is it realistic to think I could run it for 10hrs while on the hook?
I'll have exact draw and resupply numbers in two weeks when we head to San Diego. Ultimately, I think I need a bigger alternator and the little Honda.
Old 09-19-2008
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
I hook my Honda up through the shorepower receptacle. I bought plug ends and 3 strand AC marine wire and made my own extentsion.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 09-19-2008
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
Vitesse,
It's too late for this trip, but a better way to spend the same amount of money is probably a solar panel.
I get about 30-35 amp hours a day out of my 80w panel here in Maryland, that tops you off day after day in silence and with no additional (Gas) costs.
I use about 40 a day, and carry 210 ah in my house bank, so I have a cumulative negative of 5 or 10 ah a day with just the solar and can get by for 5 days with no motor run/supplemental charging at all.
Your Link should be able to give you lots of data to work with on exactly what you need, and when.
I borrow a friends Honda 2000 only when I want to run my A/C on the hook, plug it in to my 30 amp shore power plug with a 60 dollar 30amp/15amp pig tail just like everyone else works fine, last a long time. The Honda's sustained output is around 13amp - so a cord rated at 15 is okay.
Fight Club____for Sailors Surfesq Off Topic 8375 2 Days Ago 04:16 AM
Link 2000 Battery Monitor Valiente Gear & Maintenance 24 6 Days Ago 04:04 AM
Laser 2000 in the States? sportf59 Boat Review and Purchase Forum 3 08-19-2007 03:02 PM
Lessons from the Rolex 2000 ISAF Women’s Match Racing Worlds Betsy Alison Racing Articles 0 12-06-2000 07:00 PM
2000 Olympic Games Retrospective Bob Merrick Racing Articles 0 10-11-2000 08:00 PM
