  #11 (permalink)
Old 11-11-2008
Bear
carebear186 is on a distinguished road
My sincerest apologies to one and all for my hot headed reply. It seems I had two web sites open at the same time doing some comparative research and I inadvertently posted to the wrong site. Once again appologies.
  #12 (permalink)
Old 11-29-2008
wickedrevs56
wickedrevs56 is on a distinguished road
Send a message via Yahoo to wickedrevs56
I thought the Xantrex Freedom did have a dip switch setting that would prevent overcharging??? And the previous posts are all correct about watering up batteries-- it must be done-- at least periodically -- I replace "good" batteries all the time that have gone dry-- check with Xantrex (used to be Heart Interface) about the correct dip settings (taking for granted your pals have the "remote interface" to the charger/inverter package) i have the data handy if you cannot get it send me a message and I will copy and forward----
  #13 (permalink)
Old 12-04-2008
MIKEMCKEE's Avatar
MIKEMCKEE will become famous soon enough
This spring I found that my two banks of battteries were real low on distilled water, I hadn't been able to get on the boat for awhile after I had my hip replaced. I had a solar pannel along with a duel bank charger that was supposed to go to the trickel chg, but I guess that was too much also. I solved the problem by using a electric timer like you get to turn your lights on & off at home. I just put a male & female plug on the 110V line and plugged in the timer to give the charger 1 hour of electric each day. Since then I haven't had any problem over charging my two battery banks and having the water problem.
Take Care,
Mike & Glinda
s/v Blue Bayou
Paralleling Batteries dave.verry Gear & Maintenance 79 11-27-2006 11:19 AM
Cooking On Board Sue & Larry Cruising Articles 0 06-11-2001 08:00 PM
