01-18-2009
Bender of Nails
Originally Posted by dsiddens
crimped....Then soldered...
No offense Doug, but I'd say no to soldering the crimp terminals. The OP said that he's new to this and, I don't know if you've had to refit any soldered electronics but it takes a light touch with the heat to do it properly. I assume it's earnesty, but most everyone overheats the wire, causing the solder to draw too far up. This creates a hard spot that will break under vibration. For someone who's good with an iron, sure...but definitely not for someone who's learning as he goes.
Catfish, about the only other thing I might add to the great info here is that you have a chance to develop good habits because you're starting new. The thing that I would suggest is to start thinking of yellow as the color for DC negative wires, not black. The industry is slowly changing over because one of the three colors universally used in AC wiring is black. With inverters becoming so cheap, AC is becoming far more common alongside DC wiring because you can have a few more of the creature comforts. The ABYC is slow to change, but they're recommending it now, so it won't be long before the manufacturers who wish to comply will change as well.
Oh yeah, and definitely check out the 'Resources' section of the Blue Sea website...
Cheers and good luck!
"Verbosity leads to unclear inarticulate things"
~Dan Quayle
