Battery charging with an outboard - SailNet Community
Blogs
Old 12-05-2008
pedcab's Avatar
pedcab is on a distinguished road
Hi everyone.
Thought of sharing the schematics of a voltage regulator/charge controller I have fitted to my trimaran.
The point is to regulate the voltage output from my Tohatsu OB going to the battery as well as to dissipate any excess current and/or voltage spikes that might try to overcharge the battery after it is fully charged.
The dissipation is done by means of a 12V/55W lamp that is fed throught a transistor which "opens" when the voltage reaches about 14V DC.
It has been working very well for me for quite a while now and so I thought of sharing it. Hope it is of any use to someone.
Here is the schematic
Before use there´s a calibration procedure THAT MUST BE ACOMPLISHED and which goes as follows:
1- Remove all the loads (dissipation lamps and/or lead acid battery)
2- Apply 14Vdc at the input
3- Measure voltage between TP1 and ground
4- Adjust R3 untill there´s a sudden voltage rise
And that´s it. You can now connect the dissipation loads and connect the circuit.
Notes:
-It is supposed that the output of your generator is allready rectified to DC. Most outboard manufacturers provide simple plug-and-play rectifier kits;
-Q2 must be installed in a dissipator with adequate dimensions;
-The lamp wil light and, consequently,WILL HEAT UP. Please make sure it is well away from anything sensitive to heat and in a suitably ventilated place. In my installation the lamp is on the outside of the assembly box;
-This circuit is designed for a generator with a maximum of 55W output (small outboard motors, solar panels etc). For higher power operation simply add as many Q2/L1 pairs as necessary until the desired capacity is achieved.
Pedro
Portugal
Old 12-05-2008
WouldaShoulda's Avatar
AEOLUS II
WouldaShoulda is on a distinguished road
Hey, what is this??
I just want the damn thing to go when I turn it on!!
Old 12-05-2008
pedcab's Avatar
Originally Posted by WouldaShoulda View Post
Hey, what is this??
And what exactly do you mean...
Pedro
Portugal
Old 12-05-2008
Just curious, what trimaran do you have???
Old 12-05-2008
AEOLUS II
Oh jeez...
Trimaran love.
Get a room!!
Old 12-05-2008
pedcab's Avatar
It´s a Piver Nugget 24 called Fulô
Pedro
Portugal
Old 12-05-2008
BITE ME leadmine boy...
Oh jeez...
Trimaran love.
Get a room!!
Old 12-05-2008
pedcab's Avatar
In every forum, community, etc... there a black sheep
Who the hell is this "WouldaShoulda" bloke?
Pedro
Portugal
Old 12-05-2008
A guy with a slow boat...
Old 12-05-2008
Cruisingdad's Avatar
Best Looking Moderator
Cruisingdad has a spectacular aura about Cruisingdad has a spectacular aura about Cruisingdad has a spectacular aura about
Oh jeez...
Trimaran love.
Get a room!!
I am certain that Wouldashoulda is only joking with you guys. We must assume it is his attempt at being funny. I am sure that is all it is because he knows my tolerance level for intentionally trying to start arguments (ESPECIALLY OUT OF OFF TOPIC) is zero... especially right now.
We do joke around with SD and other membres. I do it. But I make sure they are people I know first. And they all take it in stride. I do not want to turn the forum outside of Off TOpic into something dry. However, we must all be conscientious of what we say on the internet because you cannot inflect tone. I have already mentioned that I am over worked right now as it is and we are short handed. I cannot imagine anyone not trying to make the extra effort here while we are going through this period (which may be a long period).
Enough said.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Choosing Batteries Kevin Jeffrey Gear and Maintenance Articles 0 04-07-2003 09:00 PM
Choosing Batteries Kevin Jeffrey Cruising Articles 0 04-07-2003 09:00 PM
Installing a New Battery Bank Sue & Larry Gear and Maintenance Articles 0 09-26-2002 09:00 PM
Charging Batteries Sue & Larry Gear and Maintenance Articles 0 09-25-2002 09:00 PM
Boat Battery Power East Penn Manufr. Gear and Maintenance Articles 0 01-18-1999 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
