Raymarine ST60+ wind instrument - problems - SailNet Community
Blogs
Old 01-06-2009
joanna57 is on a distinguished road
Anyone got any ideas? My husband's raymarine wind instrument ST60+ suddenly started playing up - he calibrates it, it works for 2 - 3 hours, then all readings go nuts and are invalid/incorrect - so he recalibrates it - another 2 - 3 hours of working, then it doesn't work any more. Any ideas??? Raymarine just says he must take it in to get serviced - but as he's days away from land, that's not possible (yet) - so any thoughts would be much appreciated. Thank you,
Joanna
Old 01-07-2009
Gary1 is on a distinguished road
That sounds like one of two things: either a bad instrument, and nothing will work but pulling it for repair. The other thought is that the problem may be a loose/corroded/oxidized connector pin. Tell him to pull the connectors off the back of the instrument and squirt some Bo-Shield or Corrosion Block in, put the connector on/off a few times, then try recalibration and see if that works. The other problem may be the masthead unit. They have a five pin connector on the instrument mast that has the same kind of corrosion/oxidation problems.
Good luck,
Cap'n Gary
Old 01-07-2009
Thank you Gary1, I will pass the info on!!!!!
Appreciate your help!
Windward performance deseely General Discussion (sailing related) 16 01-28-2010 07:16 PM
ST60 wind initialize? mikehoyt Gear & Maintenance 5 10-02-2008 10:04 PM
Trouble Shoot Wind Instrument richfef0427 Gear & Maintenance 4 03-13-2004 03:08 AM
Autohelm wind instrument troubleshooting help needed duffer1960 Gear & Maintenance 1 10-29-2003 12:03 PM
Ayrodynamics of Sailing ZachW. Learning to Sail 9 05-30-2002 11:41 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
