06-25-2009
Actually, there are a few that would be far better at answering this question than me... There are a lot of variables to answering this, since it depends on things like the sheave size ratio, the alternator design, the idling RPM, etc...
You haven't given enough information for anyone to take even a WAG stab at this... the make and model of the alternator would be a good starting point, as would the regulator make and model,.
Originally Posted by SaltiNeil
Hello Sailing Dog, you seem to be very knowledgeable regarding this subject so I would like to ask you a question.
I have a 35 amp alternator on my Yanmar diesel engine. I am trying to calculate approximate amp output at idle or low speeds so I can figure how long to run my engine while on a mooring to replace the day's usage.
The max engine rpm is 3200 so I assume the max alternator output would be near 35 amps at 3200 rpm. But is there a formula for calculating output at 500, 1000 or 1500 rpms?
I have meters that tell me how many amp hours have been used so I am just looking to figure approximately how long I need to run the engine to replace the day's use.
Thanks so much for your time
Neil
