05-01-2009
I've never seen this called a barrier strip:
I'd also point out that a ground bus can take several forms... some use a single power post, like this:
Others will use a buss bar but the piece is actually called a BUSS BAR...A ground bus is an electrical concept, a buss bar is a piece of hardware that embodies the concept.
Originally Posted by RanAweigh
Dan,
Isn't that precisely what I said? Look again buddy "a barrier strip can also be used by linking the terminals"
