05-18-2009
The battery cut-off switch is control any electrical fire(s). Not having one and having everything pretty much direct connect - means if somethings shorts / sparks etc - you have no way to isolate the source. 1 amp load by the manufacturer is nothing until when it it is shorted. Safety first - a main cut-off switch for the battery, circuit breakers, and then fuses.
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
