05-21-2009
Best Looking Moderator
Most likely the dual purpose is a deep cycle. The dual purpose means you can use it for starting and basic electrical. Most sailboats run their house bank as a starting bank too - especially in the smaller boats.
Just get the "dual purpose". What size is it?
And just a note, explained to the best of my knowledge, is that a "starting" battery is different from a deep cycle battery in design. It has to do with the plates which, on a deep cycle, are thicker and can give more ah but also require a different charging regime to replenish the plates since you have to replenish the 'inside' of the plates versus a thin exterior. The flip side is the starting battery which has thin plates meant for a quick (high amp) burst, quick discharge, and quick recharge. However, again to the best of my knowledge, there is not a set government stadard for what thickness plates have to be to be a 'starting battery' versus 'deep cycle' versus 'dual purpose'. I think it all depends on the original design focus, how reputatable the manufacturer is, and how creative their marketing team is.
My opinions.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
