06-01-2009
Pegasus,
Not ignorant at all.
I'm not quite sure what you've already done, and what you plan.
I assume you're adding a dedicated starting battery. Is that right?
The starting battery should be on it's own ON-OFF switch. Both the house batteries -- if that's what you have wound up with -- should be tied together, preferably by directly wiring them in parallel.
The house batteries should go to position 1 on the 1-2-Both-off switch. And, you should leave this switch in the #1 position. If you like, you can run a heavy cable from the #2 position on this switch to the dedicated ON-OFF switch for the starter. In this way, you could tie the house bank to the start battery if you ever need to, but normally it would be in the #1 position.
To recap:
1. You need a dedicated ON-OFF switch for the start battery. You need to move the heavy start wire from the #2 position on the existing switch to the load side of the new ON-OFF switch. Turn if OFF when you leave the boat.
2. You need to move the house battery positive wire to the #1 position on your existing 1-2-BOTH-OFF switch. Leave it in this position all the time (your house battery load) or, if you like, turn it off when you leave the boat. This switch now becomes your HOUSE load switch and, in an emergency, could supply power to the starter (or from the start battery to the house load) by switching to the #2 position.
3. Wire the EchoCharge, according to instructions, between the house bank batteries and the start battery.
4. If you like, run a heavy cable from the #2 position on your house load switch to the load position on your start battery switch. This is for emergencies.
All cables should be protected by an appropriate CPD. ANL fuses are probably best.
Hope this helps a bit.
Bill
