Amp meter? - SailNet Community
post #1 of 3 Old 09-11-2009 Thread Starter
Amp meter?
Does having an amp meter in the charging system increase voltage drop, In other words will an amp meter increase resistance in a charginf swstem?
motion300 is offline
post #2 of 3 Old 09-17-2009
CarelessNavigator's Avatar
The amount of resistance would be unnoticeable and the voltage drop will be less than 100 millivolts.
If you are looking for an in depth explanation go to Wikipedia look up ammeter then look up shunt.
CarelessNavigator is offline
post #3 of 3 Old 09-17-2009
OOPS I didn't realize this thread was posted twice I just saw 0 replies and figured I would give a response to his question. If a mod could merge this post into the other thread then delete this one I would appreciate it. Thanks
Rigging tension meter Wayne25 Gear & Maintenance 9 08-17-2009 07:55 PM
Water Flow Meter gilsurf Gear & Maintenance 14 01-24-2007 01:09 PM
autohelm st-50 knot meter edward cortese Catalina 1 06-23-2006 07:12 PM
