Both Batteries Drain Even When Only Bank Is Selected - SailNet Community
Blogs
Old 09-29-2009
pkilty is on a distinguished road
Hi All,
I have recently purchased a 1982 Pearson 37. I have spent the last month discovering the things that let's just say the previous owner failed to mention and the surveyor failed to find. It's a great boat, but in need of some love, cash and a lot of elbow grease. I have three batteries that I know are not properly wired. One deep cycle type 24 paralleled with a wet 4d for my #1 and a single type 24 deep cycle for my # 2. I think they are all of different ages and plan on scrapping them before next season. I have a "new" 85a alternator with internal regulator.
My problem is that with the selector switch off all three batteries will hold a
decent charge for several weeks. With only #1 or #2 battery on overnight with just a very small hotel load, both #1 and #2 are dead by morning.
I have checked draw on the main distribution panel and after thinking I had an aha moment found the vhf wired to the hot bus.This accounted for the draw when the panel was 1st energized.
The only thing common besides the switch is the alternator.
Any thoughts?
Thanks,
pkilty
Old 09-30-2009
mitiempo's Avatar
Hi
Something is definitely wired wrong. Trace the wiring from batteries to main switch - I assume it's 1-2-both-off type. Find out if any wires go anywhere besides the switch and where they go. Make sure the main switch is wired properly. The hot from bank 1 should go to #1 position, hot from bank 2 should go to #2 position and common (output) should go to your distribution panel and the engine starter. Somehow I think your battery banks are common to each other regardless of the switch position and there is a draw on them with the switch on #1 or #2. I guess you should get in there with a multimeter and with the switch on 1 or 2 see which items are getting voltage. That's my best guess right now. Good luck and let us know what happens.
Brian
Old 09-30-2009
badsanta is on a distinguished road
Write it down and make a map. If you cant actually see and feel the wire the whole long way it is no guarantee it goes where you think. Label the wires as you figure out what goes to what. You also may have a bad battery that drains the system. I would take them all out to a battery store and have them charger and tested. Also batteries should be the same type and size and age as different types (gel and wet) charge at different rates.
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
Old 09-30-2009
Zanshin's Avatar
Zanshin is on a distinguished road
Do you have a multimeter? If so, perhaps your alternator is either wired incorrectly or broken. Can you disconnect the cables from the alternator and measure resistance (simple "infinite" or "full'" continuity is enough)?
Old 09-30-2009
btrayfors will become famous soon enough btrayfors will become famous soon enough
Originally Posted by pkilty View Post
Hi All,
Any thoughts?
Thanks,
pkilty
There you have it! If the alternator is indeed "common" to both banks, then they are effectively paralleled, unless there is a battery isolator installed.
Bill
Old 09-30-2009
mitiempo's Avatar
btrayfors
yes, but that doesn't explain the dead batteries with only a small load overnight. There has to be another issue.
Brian
Old 09-30-2009
Zanshin's Avatar
Here I assumed that your alternator had 2 outputs and that an internal diode might have been broken. With a multimeter, measure the voltage across the + and - poles of one battery after the switch has been set to "off" for a while. With all devices switched off and breakers off, switch "on" and see if the voltage changes - even a small short dip will tell you that you've got a consumer switched on or have a current drain in your power lines. Short of an ammeter you'll have to start disconnecting devices one by one to find your problem source.
Old 09-30-2009
SteveInMD is on a distinguished road
I think you need to use a load test device on the batteries to see if they are actually good or not. If not, trouble shooting is going to be difficult.
Old 09-30-2009
davidpm's Avatar
davidpm is on a distinguished road
I second this option. First thing to find out is the condition of the batteries.
Some bad cells can cause all kinds of odd behavior. They seem to hold a charge unders some conditions then loose the charge way too fast.
First rule of troubleshooting. Don't go first to the exotic problems, rule out the mundane first.
I have taken my batteries to the nearest NAPPA store and let them charge and load test them.
They can tell you their exact condition.
Old 09-30-2009
timebandit's Avatar
timebandit is on a distinguished road
I thinking the batteries also.
It seems like with three batteries you should be able to pull 10 amps all night and not kill the batteries and it should be easy to find a load that big.
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
Paralleling Batteries dave.verry Gear & Maintenance 79 11-27-2006 12:19 PM
Battery Bank Design Kevin Jeffrey Gear and Maintenance Articles 0 05-12-2003 09:00 PM
Battery Bank Design Kevin Jeffrey Cruising Articles 0 05-12-2003 09:00 PM
Installing a New Battery Bank Sue & Larry Gear and Maintenance Articles 0 09-26-2002 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
