Iota Charger with AGM batteries - Page 3 - SailNet Community
post #21 of 22 Old 01-15-2010 Thread Starter
Senior Moment
doubleeboy's Avatar
You could run an echo charger to the start battery if you want automatic charging. The Iota stuff seems well built, is inexpensive, has great customer support. I have had mine for a month so time will tell. So far so good.
michael
doubleeboy is offline
post #22 of 22 Old 01-15-2010
mitiempo's Avatar
I have had no problem with Xantrex chargers or the Echocharge but if you widh to avoid them there is another inexpensive option to charge the start battery. The Blue Seas Automatic Charging Relay SI-Series Automatic Charging Relay - Blue Sea Systems
It will automatically open when a charging voltage is present and close to separate the batteries when voltage drops. It is also dual sensing so if you wish you could run the alternator to the start battery and the charger to the house bank. The ACR senses for both directions. It's less expensive than the echocharge by a bit. Whatever you purchase make sure no charging is routed through the battery switch for a simpler less confusing system.
Brian
mitiempo is offline
Paralleling Batteries dave.verry Gear & Maintenance 79 11-27-2006 12:19 PM
house batteries seac Gear & Maintenance 9 08-23-2004 05:28 AM
