Best connect to parallel batteries? - SailNet Community
post #1 of 6 Old 01-10-2010 Thread Starter
Irrationally Exuberant
If you've got two Group 27s with screw terminals and lug terminals (or whatever you call the typical auto clamp on terminals) and you're going to connect them in parallel, which terminals do folks usually use for this, the screw ons or the lugs? I haven't gotten the cables yet, so I can go with either.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #2 of 6 Old 01-10-2010
The automotive terminals can carry more current than the studs, so I would connect the batteries in parallel with the automotive terminals, and whatever you have to charge them with. Needs for the vessel can come off the studs, depending on current demand.
Good Luck
Kary
SV Mariah
#49080
75R20 is offline
post #3 of 6 Old 01-10-2010
Just as important is the wire gauge and how the cables are put together. I would favor a pre-made cables over ones that you might make yourself as there would be less chance for corrosion and power loss.
Dan
Tartan33R
CaptainDan99 is offline
post #4 of 6 Old 01-10-2010 Thread Starter
Thanks Dan and Kary. I will definitely be using premade cables sized generously. Scoping it out now so I get them right
Tom K
2000 Beneteau 331
arf145 is offline
post #5 of 6 Old 01-10-2010
mitiempo's Avatar
Here's a link on how to make battery cables the right way if you wish to make them yourself. Making Your Own Battery Cables Photo Gallery by Compass Marine at pbase.com
If you decide to purchase them GenuineDealz.com - Marine Electrical, Boat Wire & Cable, Custom Battery Cables will do the crimps for $1 labor each plus parts. Their prices for cabling and lugs are excellent as well.
Brian
mitiempo is offline
post #6 of 6 Old 01-11-2010 Thread Starter
Preaching to the choir, mitiempo. You (or another sailnetter) pointed me to GenuineDealz in an earlier thread related to this project and I'm locked in
Tom K
2000 Beneteau 331
arf145 is offline
Paralleling Batteries dave.verry Gear & Maintenance 79 11-27-2006 12:19 PM
Boat Battery Power East Penn Manufr. Gear and Maintenance Articles 0 01-18-1999 08:00 PM
