Remove fuse from older panel? - SailNet Community
post #1 of 14 Old 02-01-2010 Thread Starter
1975 Newport 28
jaschrumpf's Avatar
My boat has the older DC electrical panel with fuses rather than breakers. How do those things come out? The front of the panel has red squares, and I assumed one pushed on them and they were spring-loaded to pop out.
That seems not to be the case.
Looking at the back provides no clues, as there is a common bus connecting them all that is soldered on -- can't get 'em out from the back.
Do I just pry the red square out from the front with a screwdriver or something? It's gotta be simple, right?
S/V Free Spirit
Monrovia, MD
jaschrumpf is offline
post #2 of 14 Old 02-01-2010
Irrationally Exuberant
Call me stupid, but are you sure those aren't circuit breakers? That's a blurry picture, but it looks (here on the blurry side) like those are switches on the right and indicator lights on the left.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #3 of 14 Old 02-01-2010
Open the panel, if they are fuses, glass tupe with silver caps on each end, then you can pull them easily with a fuse puller, frequently included in replacement kits. If there are no glass tubes, it could be the newer auto type fuse. Compare to your car. They have fuse pullers also.
Mark1948 is offline
post #4 of 14 Old 02-01-2010
I've met the same panels. If you look at the side of the red square "button" which is away from the switch, you should see a small hole in the red plastic, right in front of the metal surface. Stick a toothpick or paper clip into that hole and it releases a small tab, then the red plastic square pops out, followed by the fuse and a spring which may try to rocket into the bilge.
If you break that little tab off, there's no way to conveniently fix it, so do take care. This is a matter of "zero" effort if you do it right, not forcing it.
They work pretty well, all told, and probably were much cheaper (and more "modern" in style) than conventional fuse holders that needed threads to screw down.
The fuses are conventional glass (AGC is it?) automobile type fuses.
hellosailor is offline
post #5 of 14 Old 02-01-2010 Thread Starter
1975 Newport 28
jaschrumpf's Avatar
Here are some better pics of the front and back of the panel. The red squares are labled "Fuse," but the back doesn't look like anything is removable, or else I'm just losing my mind and missing the obvious -- which wouldn't surprise me.
I've rewired this panel with better gauge wire since the picture was talken, but the layout is still the same: main power comes in to the right side common bus, a lead goes from the other end of the fuse to the switch. The switch is just a switch to let me turn the power on and off to that circuit in the boat. The fuses on the right (left in the front picture) are doing the circuit protection as far as I can tell.
S/V Free Spirit
Monrovia, MD
post #6 of 14 Old 02-01-2010
mitiempo's Avatar
What happens if you push on the red squares marked fuse? Does that possibly release a clip or catch allowing the fuse to pop out? They definitely come out the front.
Brian
mitiempo is offline
post #7 of 14 Old 02-01-2010 Thread Starter
1975 Newport 28
jaschrumpf's Avatar
Well, that's what I said in the OP: I thought they were spring loaded, but pushing on them does nothing. It's probably the original panel from 1975, but of course the PO didn't know anything about it nor does the owner's manual go into that detail.
I'm just hoping someone with a similar panel on another old boat knows what these things are all about.
S/V Free Spirit
Monrovia, MD
post #8 of 14 Old 02-01-2010
Hmmm
Bilgewater's Avatar
Look at this post from Hellosailor, it's correct in every way including being careful not to break it. I had a panel just like this on an old boat of mine. However, I've also seen them with a small slot in the side and a mini jewellers flat head screwdriver works well but be gentle with it.
Impulse III
Truant Pilothouse
Bilgewater is offline
post #9 of 14 Old 02-01-2010 Thread Starter
1975 Newport 28
jaschrumpf's Avatar
Great! I'll have a close look at the panel next time I'm on the boat.
Thanks to all for the help!
S/V Free Spirit
Monrovia, MD
post #10 of 14 Old 02-01-2010
Jase, the little slot is to the left of the letter "F" in "FUSE". Some of us need reading glasses to see it, but it IS there. There's no other way into those fuses without ruining the panel.
I've got one of those panels sitting around with just 5 fuse plates on it, I can tell you for sure what happened to ruin the sixth.
A Little Help from the Sun Don Casey Cruising Articles 0 12-20-2001 08:00 PM
Choosing and Installing Solar Panels Sue & Larry Gear and Maintenance Articles 0 11-06-2000 08:00 PM
