- Quick Menu
02-21-2010
MPPT Solar Caution ...
Funny thing happened ...
I've been using a Blue Sky MPPT charger for a solar system, but because of all of the snow the panels were covered up and not charging and the loads drained the battery bank, just one of those rare things that happens sometimes. Well, the funny part is this - if the battery bank gets too low, the MPPT charger stops working, completely, because it is powered by the battery bank and not by the solar panels, so even if the snow melts and the solar panels are powered up, the charger and battery bank remain dead. Ask me how I know.
What are you pretending not to know ?
02-21-2010
Your batteries have to be pretty dead for this to happen though.  And it doesn't happen with all the MPPT charge controllers...but it is an issue on the Bluesky SB2000E among others.
02-21-2010
Like maybe 9.6 volts.
02-21-2010
Considering a 12 vdc battery is considered 100% discharged at 11.6 VDC....9.6 VDC is pretty bad...Might consider getting a batteryminder just in case.
02-21-2010
Yeah I think I'm going to use a relay to wire up a low voltage disconnect and run all my loads through that, if i have a zener with a voltage somewhere around 11 volts ..
02-21-2010
On second thought, that circuit might just sit there and flicker on and off at the cutoff voltage, maybe I should just get the battery minder.
02-21-2010
Nah, go with your home-made contraption and report back at what it does...
02-21-2010
Did you have a load running on the boat to drain the bank when there was no solar input? Otherwise, I'm confused, 'cuz the solar panels should have diodes to prevent "leakage" when the sun don't shine and at night.
Stu Jackson, C34, 1986, M25 engine, Rocna 10 (22#)
02-21-2010
Yes, there was a load.  Usually it isn't a problem, the load is light compared to the input from the solar panels even averaged through cloudy days, etc, I just wasn't counting on the solar panels being covered in snow for weeks.
| Thread Tools |
Search this Thread |
You may post attachments
You may edit your posts
