Battery Charger doesn't - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance > Electrical Systems
Old 03-24-2010
ereiss is on a distinguished road
Plugged the boat in to shore power (120v). Turned 120v panel on, turned on battery charger.
Charger lights up, makes sounds but batteries don't charge. Checked the connections, they are tight.
One every few minutes there is a "ping" noise coming from the charger area.
Sorry to sound so ignorant but, I guess I am in this regard.
Any suggestions would be appreciated.
regards,
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 03-24-2010
k1vsk will become famous soon enough
What is the battery voltage and what voltage is there at the output of the charger? What charger is it? How old? Have you removed and cleaned all connections?
Kind of difficult to deduce anything without that info.
  #3
Old 03-24-2010
I"d point out that some chargers won't charge severely depleted batteries. Take the charger off and see what voltage the batteries are at. If they're below 10 vdc, it is likely that they're dead. While you're at it, check the voltage between the leads on the battery charger... should be about 14.4 vdc or so.
  #4
Old 03-24-2010
mitiempo's Avatar
mitiempo will become famous soon enough mitiempo will become famous soon enough
Some chargers also have internal fuses while some are external. Check your charger manual. If internal it could be blown.
Brian
  #5
Old 03-24-2010
75R20 is on a distinguished road
The "Ping" that you are hearing is likely the circuit breaker in the charger opening with too much current. Either your batteries are bad or there is a problem with the charger/wiring/circuit breaker, allowing too much current to "open" the breaker. " Most chargers use a thermo breaker that automaticly resets when it cools down, current flow heats it normally. Too much current, and it gets too hot, and opens. The breakers can wear out, but are pretty realible.
Best of luck
Kary
S/V Mariah
#49080
  #6
Old 03-24-2010
Charger doesn't
Thanks, the batteries are low (reading about 12.0 or lower). I'm going to bring my car charger and give them a boost before I try again.
Thank you all for your help.
  #7
Old 03-24-2010
mitiempo's Avatar
Chargers that are working should have no problems with batteries at 12 volts or thereabouts. It's a totally dead battery that stalls some chargers.
Brian
  #8
Old 05-10-2010
SoulVoyage's Avatar
seeker of wonder
SoulVoyage is on a distinguished road
I basically have the EXACT same problem right now, except I don't have the clicking sound coming from the charger. My shorepower charger is an older Guest 15/20 amp simple non-multi-step, 2-bank ferro-resonant charger.
On mine, I have checked the voltage at the charging wires themselves with no battery hooked up, and it reads a low 12.55 volts instead of its listed 13.8 volts. But when I put the terminals on a moderately discharged it'll read 11.40 volts and stay there in definitely, without bringing the battery up to charge in the least.
Because of this, I am thinking bad diodes or maybe internal windings in the charger haver gone bad. Anyone know if these chargers can be re-wound or replace the diodes...probably cheaper doing that than buying a new $300 charger, which I rather not do. Any ideas?
When I put an automobile charger on the batteries, they came up to life very quickly, so the problem is not the batteries.
"...and a star to steer her by."
  #9
Old 05-10-2010
Broomfondle is on a distinguished road
ereiss – assuming that your charging setup used to work then all you need to do is find out what has changed. I know that sounds a bit supercilious but I actually find it quite a useful diagnostic principle. On a boat the most common cause of change is corrosion or water getting in (it is on my boats anyhow). So I’d check all the wires visually and probably prod them a bit. If that is all good then I’d focus on the charger. The open circuit voltage should be around 13.8v and it should be close to this when charging. Breakers and fuses may have been doing their job but if one has gone you should always ask why (see water and corrosion above).
soulvoyage – your charger is broken. Same question – what has changed? Open it up and have a careful look. Scorch marks are a good clue. Without some specialised knowledge and a bit of kit you may find it difficult to diagnose at the component level. Might be able to find someone or even send it back to the manufacturer.
Lead philosopher to the Nuno team
  #10
Old 05-10-2010
mitiempo's Avatar
SoulVoyage
Your Ferro-resonant charger probably should be replaced with a modern 3 stage. Your batteries will appreciate it.
Brian
You may post attachments
You may edit your posts
Reconditioned Batteries dryclean Gear & Maintenance 10 03-18-2010 08:28 AM
Battery Bank Design Kevin Jeffrey Gear and Maintenance Articles 0 05-12-2003 08:00 PM
Battery Bank Design Kevin Jeffrey Cruising Articles 0 05-12-2003 08:00 PM
Installing a New Battery Bank Sue & Larry Gear and Maintenance Articles 0 09-26-2002 08:00 PM
Boat Battery Power East Penn Manufr. Gear and Maintenance Articles 0 01-18-1999 07:00 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
