Depth transducer test ? - SailNet Community
post #1 of 3 Old 05-01-2010 Thread Starter
I installed a new Raymarine ST60 depth instrument; must the boat be in the water for the transducer to operate correctly?
Rewards is offline
post #2 of 3 Old 05-01-2010
mitiempo's Avatar
Yes
Brian
mitiempo is offline
post #3 of 3 Old 05-02-2010
You can try a bowl of water under the boat to refect the sound waves. There is considerable loss at the trasducer/air interface, but it does work some of the time.
The depth reading will be incorrect due to the speed of sound in air rather than water, so a correction factor (which I forget) needs to be applied.
If it does work you can be confident that everything is working as it should be before launch
noelex77 is offline
The Salt's Corner Table smackdaddy General Discussion (sailing related) 129 06-18-2013 05:46 PM
Mounting depth finder transducer. davidpm Gear & Maintenance 16 04-17-2010 09:23 PM
Standard Horizon Depth Sounder replacement Mytilene Gear & Maintenance 6 06-19-2006 03:31 PM
Depth Transducer Question gwp Gear & Maintenance 0 07-13-2003 06:38 AM
Installing Depth Finders Tom Wood Gear and Maintenance Articles 0 03-01-2002 08:00 PM
