How to wire this switch panel - SailNet Community
post #1 of 6 Old 05-31-2010 Thread Starter
I'm trying to wire up this old switch panel, but it looks different than the diagrams in Casey's book as far as I can tell.
This is a poor photo, but the left side has the positive going out to say, a light.
Are the right two terminals for positive and negative to the battery, respectively?
I was thinking I'd just have to send one positive and one negative wire to it, but maybe that's not the case. I'm also a little confused b/c this is a very old panel and has been used before, but the right terminals look like they'd require a soldered connection, but I see no signs of previous soldering on there.
99miles is offline
post #2 of 6 Old 05-31-2010
Don't bother. Sooner or later, it will only bring you grief.
Do yourself and your Cal 24-2 a favor and spring for a new panel, like this one: Blue Sea Systems #1459 Panel 360 DC 4 POS Switch CLB + V M V
While you're at it, revisit Casey or, maybe, Charlie Wing's excellent book:
Amazon.com: Boatowner's Illustrated Electrical Handbook (9780071446440): Charlie Wing: Books
The $23 will be the best you ever spend on your boat :-)
Bill
btrayfors is offline
post #3 of 6 Old 05-31-2010
kd3pc's Avatar
2nd vote for a new panel, and get some duplex marine cable while you are at it....
Casey's book is excellent. As is Charlie's.
Will be more reliable and much safer than "fixing" this one.
kd3pc is offline
post #4 of 6 Old 05-31-2010
mitiempo's Avatar
I agree, get the new panel.
On the pic the fuse is on the left and the wire goes from the fuse to the left side of the switch. Note the left side of the switch has the same 2 connections and how the wires are attached. The right side of the switch is for the positive output to the load (gps, light, etc).
Lots of panels do not have a place for the grounds and it isn't necessary anyway as you're only switching the positive. Blue Seas 360 panels do not have ground connections as one example. They usa a separate connecting point, usually a small bus or terminal block.
Brian
mitiempo is offline
post #5 of 6 Old 05-31-2010
mitiempo's Avatar
The panel that Bill linked to is a 360 series panel and as I posted the grounds go to a separate bus. The only reason there is a ground on the panel at all is for the led indicator lights. From the manual for the Blue Seas panel:
Brian
mitiempo is offline
post #6 of 6 Old 06-01-2010 Thread Starter
Thanks everyone. I did get it working today, but I think I'll take your advice and upgrade the panel and wiring.
99miles is offline
Locating the master battery switch / DC Panel - Wire cost jarcher Gear & Maintenance 13 04-20-2010 01:06 PM
Keeping Wiring Woes at Bay Chris Brignoli Gear and Maintenance Articles 0 01-26-2004 08:00 PM
Choosing and Installing Solar Panels Sue & Larry Gear and Maintenance Articles 0 11-06-2000 08:00 PM
Electrical Work Rules Don Casey Gear and Maintenance Articles 0 07-16-2000 09:00 PM
