GPS an the Compass - SailNet Community
post #1 of 37 Old 06-24-2010 Thread Starter
chuckg5's Avatar
GPS an the Compass
Just got off the phone with a Garmin tech. the last few years my 3206 garmin gps has been placed near the hatch about 5-6 feet away from the wheel. not so easy to see and hard to change screens an what not. now I've bought wire to extend the cable (20 different strands!) to mount in front of the wheel AND the 5" danforth compass. My question to the tech was "will it affect the compass heading?" The answer was "yes" and there is no way to compensate , swing , the compass to get it right. That's no fun. He says to mount it at least 3' from the compass to not affect it. Anyone else going thru this?
chuckg5 is offline
post #2 of 37 Old 06-24-2010
Chesapeake Sailor
wwilson's Avatar
Chuck,
That is a Garmin 3205 on the pedestal port side and the compass right above it. The two have gotten along without interference since 2007.
I would add that newer Garmin chart-plotters apparently use a magnetic latch on the cartography card door. Not so good...
Wayne
s/v Virginia Dare
wwilson is offline
post #3 of 37 Old 06-24-2010 Thread Starter
chuckg5's Avatar
maybe the garmin tech was being overly careful. i'm going to do it tommorow, wire it up, and see if there is a difference. can alway check it against the compass on the gps!
chuckg5 is offline
post #4 of 37 Old 06-25-2010
Stu Jackson's Avatar
Be careful if there's a current.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #5 of 37 Old 06-25-2010
mitiempo's Avatar
It has been my understanding that dc wires within 3' of a compass should be twisted and not parallel to eliminate magnetic fields that can cause compass error.
Brian
mitiempo is offline
post #6 of 37 Old 06-25-2010
nickmerc's Avatar
I have one of the new Garmin chartplotters with the magnetic latch (in my opinion a bad design). The literature noted the 3' recommendation. I mounted it about 20" away from my compass without any known issues.
As for considerations with the electrical look how your compass light wires are handled. I do not think most of them are twisted pairs. As long as you have the positive and negative wires very close together, touching, you should be fine for EMF.
________
Electronic cigarettes
nickmerc is offline
post #7 of 37 Old 06-25-2010
Angry
If your Garmin has the older friction catch on the chart chip door, no problem. Where they went off the rails, design-wise, was going to a powerful permanent magnet for the chip door on the newer ones. Their install instructions specify 39" from the compass to try and fend off wrongful death suits.
As pointed out before, boats with binnacle mount instruments or console mounted instruments by a steering compass must be considered some sort of vanishing niche market for Garmin these days.
L
olson34 is offline
post #8 of 37 Old 07-01-2010
Old Gaffer
FishSticks's Avatar
I have a new Garmin 546 plotter mounted right at my binnacle compass. This is only practical if you open up the unit and remove the internal magnet that is used to keep the SD chip door closed. Garmin was no help when I called them about this, saying this action would void my warranty. They suggested that "the inductance from the display is the main problem." That proved to be untrue and there is no compass deviation from the display with the magnet removed. Notwithstanding this curious design feature the 546 is a good plotter. The binnacle installation is ideal for many boats, and the fact you can pivot and tilt the display for optimum viewing wherever you sit or stand is a great advantage.
The magnet I removed is powerful enough to pick up a good sized wrench. I intend to fasten a strong fishline to it for retrieving tools and miscellaneous parts from my bilge.
Never sail closer to the wind in degrees than your age
FishSticks is offline
post #9 of 37 Old 07-01-2010
The magnet was a really stupid idea from Garmin IMHO. Unfortunately, it won't be all that useful with retrieving parts, as most boat parts are non-magnetic. Marine grades of stainless steel, bronze and aluminum are all non-magnetic.
sailingdog is offline
post #10 of 37 Old 07-02-2010
Old Gaffer
FishSticks's Avatar
When you have a 1939 wooden boat with inaccessible bilges there are always fossils that can be mined with a magnet, and this one is highly effective.
It would be really interesting to find out how this deliberate act of compass terrorism made it through the Garmin bureaucracy's design approval process. My guess would be that Garmin's marine products are now dwarfed by their consumer automotive products and they were forced to do this as a matter of cost-cutting. In fairness however, Lowrance now has a plotter with a magnet latch as well.
GPS Gets More Accuracy Jim Sexton Seamanship Articles 0 05-21-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Gear and Maintenance Articles 0 05-21-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Cruising Articles 0 05-21-2000 08:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Seamanship Articles 0 03-01-2000 07:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Her Sailnet Articles 0 03-01-2000 07:00 PM
