spotty ignition - SailNet Community
post #1 of 4 Old 07-08-2010 Thread Starter
QuickMick's Avatar
spotty ignition
Keyed ignition in the cockpit to start my A4 is acting funky. She works... then she doesnt... i climb in the quarter berth and jiggle the wires (scientific, i know) and she will fire off again. anyone know a good procedure to isolate the problem? frankly all wires could probably stand to be replaced if this is the problem or not... just looking for a way to diagnose the issue.
thanks all
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Macgregor Venture
QuickMick is offline
post #2 of 4 Old 07-08-2010
T37Chef's Avatar
Sounds like a bad connection and/or corrosion. Check all the wiring and connections and maybe replace some while your at it. I had a similar problem soon after we purchased our boat, it was a corroded negative wire on the battery terminal, replaced the lugs and added heat shrink tubing and all is well.
Shawn
T37Chef is online now
post #3 of 4 Old 07-08-2010
Pearson 303
SVCarolena's Avatar
T37 is right on the money, IMHO. In addition, from my experience years ago as an auto mechanic, you may ultimately find it easier and quicker to just replace the wiring, rather than trying to track down the one bad connection. Diagnosing intermitent electrical problems is one of the most time consuming and maddening projects I've ever encountered.
SVCarolena is offline
post #4 of 4 Old 07-09-2010
NON member
AE28's Avatar
We had intermittent problems - sometimes she'd crank, sometimes she wouldn't - and solved it by running a new tinned wire (don't remember the gauge) from the starter button directly to the solenoid.
Paul
AE28 is offline
yanmar ignition key arman Gear & Maintenance 10 05-16-2011 06:28 PM
ignition switch, alternator, ???? seaduced8104 Electrical Systems 3 06-03-2010 06:19 PM
ignition problems universal seaduced8104 Diesel 3 05-22-2010 07:58 PM
ABYC Ignition Protected Fuse Panels ncstatesailor Boat Review and Purchase Forum 5 12-15-2009 12:30 PM
