Air Breeze Output in FL and Bahamas..? - SailNet Community
post #1 of 2 Old 08-20-2010 Thread Starter
I'm wrestling (mentally) about how to supply my elec needs/wishes.
This boat will be mostly used in FL and the Bahamas and I'd like to hear from other people's experiences with the Air Breeze - what the real-life output has been in this region.
According to my figuring, I'll need to meet a max of 100 amp/hrs per day.
The boat is a late 70's Watkins 27 that will be running a 12v portable fridge (in fridge mode, not freezer), a tillerpilot for short durations, minimal LED lighting, and a lil bitty laptop. The alternator puts out a whopping 35 amps, but I'd rather cover the elec needs without counting on its use.
Real-life experiences are usually better than manufacturer specs.
Thanks in advance.
RegisteredUser is online now
post #2 of 2 Old 08-20-2010
I'd first recommend you buy and install a battery monitor, as this will allow you to accurately measure what your actual usage is. Basing your usage on wild guesses can lead to spending a lot of money where it isn't needed or not buying the right equipment to address your needs.
sailingdog is offline
