45 watt solar array - SailNet Community
post #1 of 7 Old 09-15-2010 Thread Starter
islander bahama 24
newhaul's Avatar
45 watt solar array
2 friends of mine just gave me 2 harbor freight 45 watt solar arrays and i was wondering if i could hook up both charge controllers to one battery or do i need either 2 batteries or larger controller the one that came with the kit will only handle up to 6 amps each. array puts out 4.75 amps each.
newhaul is offline
post #2 of 7 Old 09-15-2010
You'd do much better having a single controller that can handle both arrays. If you use two controllers, you'll have the problem that the output from one can cause the other to cut back, and then you won't really be getting the full charging capability of either panel array.
sailingdog is offline
post #3 of 7 Old 09-15-2010 Thread Starter
islander bahama 24
newhaul's Avatar
ok thats what i thought i have figured my useages and one array would do the job most of the time however in the winter i may need to add a couple amps over the output of one pannel and was wondering if it would workas a booster. i was looking at a biggwer controller but cant afford it right now maybe in spring
newhaul is offline
post #4 of 7 Old 09-20-2010
MacGyverRI's Avatar
You need to flip the charge controller switch off in late afternoon (5-6 pm) or it discharges. Back on in morning.
I have the same array and it works great!
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
MacGyverRI is offline
post #5 of 7 Old 09-20-2010 Thread Starter
islander bahama 24
newhaul's Avatar
thanks for the heads up i am going to place blocking diode in line under 5 bucks at rat shack
newhaul is offline
post #6 of 7 Old 09-20-2010
MacGyverRI's Avatar
Nope, no diode w/ a controller!
The charge controller has to see the battery voltage and the panel voltage to work right. Solar Panels (no charge controller) going straight to batteries, then you can use a diode.
post #7 of 7 Old 09-20-2010 Thread Starter
islander bahama 24
newhaul's Avatar
thanks that will save me some money and time will need to upgrade controller next spring so i wont have to remember to turn it on
newhaul is offline
PSC 37 Solar array solutions granche1 Pacific Seacraft 22 11-06-2012 07:05 PM
How much is a watt-hour per day worth? Bene505 Electrical Systems 26 06-17-2010 06:18 PM
Need new replacement 25 watt VHF Radio Chaunclm Gear & Maintenance 11 02-07-2008 02:56 AM
difference between open array and radome daddyhobbit Gear & Maintenance 3 01-02-2008 11:36 AM
Siemens 65 Watt solar panels pjfsail Cruising & Liveaboard Forum 10 07-21-2003 09:30 AM
