Xantrex/Heart Freedom 25 -- How to connect Water Heater - Page 2 - SailNet Community
post #11 of 65 Old 10-20-2010
mitiempo's Avatar
Here it is:
Brian
mitiempo is online now
post #12 of 65 Old 10-20-2010 Thread Starter
Glad I found Sailnet
Bene505's Avatar
Remetau -- good input on the effectiveness of heating via wind. The second dump load is just in case the water is already hot.
Here are a couple of options, based on some of the input here.
This first one uses a dump load controller to trigger a relay which lets powerf flow from the Freedom 25 inverter whenever the battery voltage starts getting too high from the wind generator charging.
This next picture uses a second inverter that I already have in place. The dump load controller sends battery power to that inverter, which in turn powers the hot water heater.
I made these diagrams this morning, before I realized there were dual input heating elements.
I'll have to make another diagram using the 110v/12v heating element.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #13 of 65 Old 10-20-2010 Thread Starter
Bene505's Avatar
Originally Posted by mitiempo View Post
Here it is:
Any idea how the 12v heating element knows when to turn off? The 110v circuit must run through a termostat of some type. I would think that the same thermostat couldn't be used with 12v at the same time.
I wouldn't want to create a boiling/exploding hot water heater ala mythbusters.
Regards,
Brad
Bene505 is offline
post #14 of 65 Old 10-20-2010 Thread Starter
Bene505's Avatar
Here's the diagram with the dual element. It's much simpler, eliminating all relays.
Regards,
Brad
Bene505 is offline
post #15 of 65 Old 10-20-2010
Stu Jackson's Avatar
Brian's post is interesting and would be what you're looking for. Please note it's only 500 W at 120V. Most 120 V heaters are 1500 W.
All the 300 W and 500 W ratings mean is that it'll take longer to heat your water.
From your use descriptions, it sounds like what you're doing is elective, and not necessary.
Here's why:
When you've finished motoring to an anchorage, your water will be hot. After a day at anchor, not more hot water, but your wind machine will provide your hot water heating. No wind? Use your inverter, but that's not a good idea unless you have a HUGE house bank.
I wonder how the combined 12V/120V heater element is wired to have two sources to the same element without MANUAL switching between the two different voltage inputs.
If it was my boat, I'd keep it simple. Wind dump to house bank. Either choose 12V or combined 120V/12V heater element. Do the switching manually with a simple dump. Forget using the inverter for hot water.
Every time something else is added, it requires a backup, so plan on bypasses around what you add or backup "pieces" of "stuff."
Toggle switches are good bypasses!
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #16 of 65 Old 10-20-2010
One other thing
Unless your boat is actually wired that way, your diagram is wrong.
You should have an AC main breaker to an AC distribution panel.
The shorepower comes into the I/C, then back to the AC main breaker and then to the 110 Outlets and the hot water heater. The I/C has the transfer switch inside it.
post #17 of 65 Old 10-20-2010 Thread Starter
Bene505's Avatar
Originally Posted by Stu Jackson View Post
One other thing
Yes, that's the way it is (or it will be once I install the Freedom 25 I/C). I think I typed that I was leaving the breakers out of the diagram to keep it simple.
Regards,
Brad
Bene505 is offline
post #18 of 65 Old 10-21-2010
Brad, it's not the breakers, it's the basic flow of electrons in the wiring. As shown, for instance, you couldn't power your water heater form the Freedom I/C.
post #19 of 65 Old 10-21-2010
mitiempo's Avatar
Stu
From what Brian said earlier I don't think he wants to heat water with the invertor.
Brian
post #20 of 65 Old 10-21-2010
Yup, could be, Brian, but the basic misunderstanding or misrepresentation of how the connections are made is what disturbs me, and they so should for him.
Batteries drinking a liter of water each / Xantrex granche1 Electrical Systems 4 07-27-2010 01:59 PM
xantrex freedom marine 1500 inverter/charger issues ncstatesailor Gear & Maintenance 1 04-09-2010 07:57 PM
I need a Xantrex Freedom remote panel, Link or Standard, Used or ugly OK TommyboySD Gear & Maintenance 0 04-22-2009 07:33 PM
Connecting raw water cooling to water heater Northeaster Gear & Maintenance 18 04-28-2007 07:11 PM
hot water heater firstafair General Discussion (sailing related) 12 11-09-2006 11:25 AM
