Xantrex/Heart Freedom 25 -- How to connect Water Heater - Page 7 - SailNet Community
post #61 of 65 Old 10-25-2010
Stu Jackson's Avatar
Originally Posted by Bene505 View Post
I plan to label the breakers as hot even when the main breaker is thrown, with a note to "check to make sure the inverter is off".
Gee, that's one of the reasons I really like wiring option 1, because everything comes thru the main AC breaker on the boat. When it's off, "you don't need no stinkin' signs" saying you can be electrocuted even if the main power switch is off.
Just my simple approach... KISS, consider it, Brad. Bypassing the inverter makes less sense since you mentioned this, I'd forgotten the unforeseen and unintended consequences.
All the best, glad we could, and will continue, to help.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #62 of 65 Old 10-25-2010
mitiempo's Avatar
Stu
That's why I like the main panel to inverter to sub panel plan. It makes it real obvious what the inverter is able to power.
Brian
mitiempo is offline
post #63 of 65 Old 10-25-2010 Thread Starter
Glad I found Sailnet
Bene505's Avatar
On the panel there's a green light when shore power is supplied. I could put another one of those in the panel to show that there's inverter power being supplied. There's just enough room for it. I'll have to think again about the other approaches, when I make some time for that.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #64 of 65 Old 10-25-2010 Thread Starter
Bene505's Avatar
Here are some pictures of the breaker panel. First the front of the panel.
And a zoom-in of the front of the panel.
Then the back of the panel. There is a bus bar that I think I can remove and use wires instead. It is the thing that has the number 004938 on it.
Each breaker handles two wires (hot and neutral, IIRC). There is a common ground strip (at right). The circuit breaker for the outlets is wired to 2 strips (hot and neutral) for all the outlets to tie into (at left).
Here's a zoom-in of the main breaker.
Looks like all the AC outlets have ground-fault-detectors, except for the new ones the PO added. I'll have to look into that.
Regards,
Brad
Bene505 is offline
post #65 of 65 Old 10-25-2010
mitiempo's Avatar
I think I prefer Blue Seas panels.
All double pole though, breaking hot and neutral. More like what you should see on a metal boat.
Brian
mitiempo is offline
Batteries drinking a liter of water each / Xantrex granche1 Electrical Systems 4 07-27-2010 12:59 PM
xantrex freedom marine 1500 inverter/charger issues ncstatesailor Gear & Maintenance 1 04-09-2010 06:57 PM
I need a Xantrex Freedom remote panel, Link or Standard, Used or ugly OK TommyboySD Gear & Maintenance 0 04-22-2009 06:33 PM
Connecting raw water cooling to water heater Northeaster Gear & Maintenance 18 04-28-2007 06:11 PM
hot water heater firstafair General Discussion (sailing related) 12 11-09-2006 10:25 AM
