Old 11-10-2010
ccriders is on a distinguished road
Measuring Battery Voltage
I have a two prong outlet in the companionway near the DC panel. If I measure the battery voltage at this point with a digital multimeter, how accurate of a reading can I expect?
John
Old 11-10-2010
Maine Sail's Avatar
John
What are you trying to determine with this reading?
______
-Maine Sail / CS-36T
Old 11-10-2010
peikenberry's Avatar
peikenberry is on a distinguished road
The most accurate is at the battery
Ike
My Boat building Web Site
My Boating Safety Blog
Dont Tell Me that I can't. Tell me how I can!
Old 11-10-2010
mitiempo's Avatar
Very accurate for that point in the system. As posted the battery is the best place for voltage measurement and a voltmeter is usually wired direct to the battery. When nothing else is drawing power they should be close, the battery voltage a bit higher. If there is a large difference there is too much resistance somewhere from corrosion or an otherwise bad connection. Measuring voltage occasionally at different places on the boat can sometimes show problems you didn't know existed.
Brian
Old 11-11-2010
rmeador is on a distinguished road
If there is no load on this DC outlet, it should be a very accurate representation of the battery voltage. The voltmeter barely draws any current, so the voltage drop through the wires to the outlet will be negligible. If you're measuring it while it's under load, all bets are off.
1979 Gulfstar 37 Laissez Faire
Old 11-13-2010
Thanks for your responses. I'm trying to keep track of battery status without replacing the current battery meter, which is worthless. The companionway outlet is very convenient and means I don't have to climb down into the cockpit locker, move a bunch of stuff open up the battery boxes and measure the batteries. There is probably six feet of 16ga wire (new) between the outlet and the terminal strip plus three feet of 16ga wire (new) between the switch panel and the terminal strip and then three feet of old wiring between the switch panel and the battery switch and six (?) feet of cable to the batteries. My guess that there has to be some voltage drop, but not significantly so. Based on the above comments a battery meter should be attached directly to the batteries, is that true? What gauge of wire should that be for say 10 -12 feet if wire?
Thanks for your help,
John
Old 11-13-2010
mitiempo's Avatar
Yes, it is true a battery meter should be attached direct to the batteries.
A simple voltmeter will tell you voltage, but voltage is a lousy way to tell battery state. Ideally you can install a real battery monitor so you always know the exact state of charge of your battery bank. Like this:
Brian
Battery Voltage Issue sailak Gear & Maintenance 20 11-13-2009 09:21 AM
Any one usig the Gobius tank measuring device? SanDiegoChip Gear & Maintenance 3 08-06-2009 02:39 PM
Basic Battery Question - measuring capacity preservedkillick Gear & Maintenance 15 06-17-2009 03:37 PM
Battery Voltage verses amps dsbentley Gear & Maintenance 6 05-01-2008 10:16 PM
Measuring Boat Speed Dan Dickison Racing Articles 0 07-02-2002 08:00 PM
