Old 11-14-2010
edwmama is on a distinguished road
Smile Battery banks must be the same or can be different?
Battery banks. Need they be the same?
Hi
My cal 46 has two battery banks and a set of two lifeline starter batteries
I have on board a xantrex MS 3000 which is a converter/charger combo
House battery bank 1 consists of 4 6 Volts batteries connected in series
And the bank 2 has two 4D 12volts bats connected in parallel
My question is 1) is there any advantage to this choice of bats
2) is it preferable to have two identical battery banks
Like two sets of 4 six volt batteries
Istead of two different banks
3) having two different banks would that in anyway adversely affect the
Performance of my xantrex MS 3000
Also my starter bats are also connected to the charging system. Is this advisable. My boat electrician installed a combiner with the wirings.
Ease reply. My email is edwmama@yahoo.com
Edwmama
Old 11-15-2010
mitiempo's Avatar
I guess you mean eries/parallel for the bank composed of 6 volt batteries.
As long as they are 2 separate banks they can be different types.
However if in one large bank, which is better both for use and the life of the batteries, they should all be of the same type and age. 6 volt golf cart batteries make an excellent house bank in numbers of 4, 6 or 8 batteries.
One bank of 8 6 volt batteries is a better choice than 2 banks of 4 6 volt batteries each.
There should not be any problems with the charger and if a combiner is installed properly the start battery should be fine.
Brian
Old 11-15-2010
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
I.E. 24Volt house bank, presumably high A/H capacity, and 12V start bank, also high A/H capacity...
Conceivably; you can reconfigure either bank to be a back up for the other. That's a good thing... But I am guessing that you have a vastly over-provisioned starter bank. If you don't need all those A/H for your starter (and I'll bet you don't) you could probably do away with one of the 12V batteries, and still survive any single battery failure.
No, the two banks serve two different purposes.
You could probably get a quantity discount when buying batteries.
Yes...
I'm gonna go out on a limb here and guess that your "boat electrician" has a better handle on your electrical system than you do.
I respectfully suggest that you buy a book that covers sailboat electrical systems, and read and comprehend it. Don Casey's Complete Illustrated Sailboat Maintenance Manual and/or Nigel Calder's Boatowner's Mechanical and Electrical Manual would be excellent places to start, AND they would cost far less than you have already spent on electrical work.
ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
Old 11-15-2010
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
Edwmama,
Not sure exactly what your situation may be, but here's a general answer.
The one thing you need to make sure of is that your battery chemistries are the same. If the 6v batteries are wet cell, then the 4D's should be wet cell also. If they are different (e.g., 6V wet cell and 4D gel), then you will likely have problems with the different charge acceptance rates.
Old 11-15-2010
Brian in bictoeia harbour
Why is one bank of 8 6 V bays better yhan 2 banks with 4 6V each
Does ont one integrated bank give longer lasting capacity ?
Edwmama
Old 11-16-2010
mitiempo's Avatar
The larger bank will not be drawn down as low as 2 smaller banks and will last longer as a result. It will actually give you more usable amps than 2 smaller banks as well due to Peukert's law. Also easier to control/monitor one bank instead of 2.
Brian
Old 11-16-2010
noelex77 is on a distinguished road
IMHO 2 banks is always better.
They can easily be combined by leaving both on.
If one battery fails its much easier to troubleshoot and isolate with 2 banks
It is easier to occasionally charge the batteries to 100%
2 battery switches adds redundancy
It allows the option in the future of partially replacing the batteries.
There are no drawbacks other than cost and slight increase in weight and complexity
For a long distance cruising boat I think 2 banks of house batteries is a very good feature.
If staying in local waters 1 bank is OK.
Battery Banks islands50 Gear & Maintenance 2 04-19-2010 08:52 AM
Battery Boxes and Banks arf145 Electrical Systems 21 03-12-2010 11:03 AM
Battery Chargers for Multiple Battery Banks btrayfors Electrical Systems 5 11-15-2009 11:57 AM
Battery Banks 1 or 2 SimonV Gear & Maintenance 9 10-25-2007 09:25 PM
Mother of All Battery Banks? Shack Gear & Maintenance 9 09-09-2006 05:52 PM
