11-24-2010
Sounds to me like you are mistaking the main positive output stud as being a diode? It is screwed into the positive heatsink plate but it is just a stud, not a diode. Remove the black plastic cover from the back of the alternator (first remove the D+ terminal hardware) and you will see the 6 diodes. 3 are pressed into the positive heatsink plate and 3 are pressed into the negative plate. The other end of the diodes are tack welded to the connector plate terminals. You cannot replace individual diodes. You must replace the whole assembly. How have you determined that you have a diode problem?
Eric
