Old 11-20-2010
kidnapper is on a distinguished road
ammeter wiring
Hi
I have a 20amp analogue ammeter that I want to mount in my switch board to monitor amperage usage from my house batteries.There is a negative bus board at the switch board that is fed from the house batteries.Will running this feed through the ammeter show amperes being used?Is this the correct way to wire it in?
Old 11-21-2010
Stu Jackson's Avatar
Stu Jackson is on a distinguished road
Ammeters have to be installed in series with current flow, and negative bus bars are rarely fed from house batteries, since feeds are positive.
Find either a positive or negative wiring run that has ALL of your current flowing through it to install the ammeter. One way is between the C post of your 1-2-B switch and your distribution panel.
Stu Jackson, C34, 1986, M25 engine, Rocna 10 (22#)
Old 11-21-2010
MacGyverRI's Avatar
MacGyverRI is on a distinguished road
2 threads on the same thing?
http://www.sailnet.com/forums/sailne...er-wiring.html
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
ammeter wiring kidnapper SailNet FAQ's 13 11-21-2010 09:27 PM
Installing an ammeter rikhall Electrical Systems 28 09-24-2010 08:42 AM
Ammeter vs. Voltmeter L124C Electrical Systems 26 09-01-2010 01:35 PM
DC Ammeter Question seap27672 Gear & Maintenance 7 07-05-2008 10:03 AM
Ammeter question jaschrumpf Gear & Maintenance 20 08-03-2007 01:46 PM
