Best battery monitor for the buck - Page 2 - SailNet Community
post #11 of 19 Old 12-01-2010 Thread Starter
Beneteau 411
I'm tentatively leaning towards four of the US Battery US2200's based upon comments I've read in this forum. I may want to do some research on the CG2 batteries sold by Sams Club and manufactured by Johnson Controls. I have no idea how they compare to the US2200's so would not go that route unless I found some real data to back them up.
prroots is offline
post #12 of 19 Old 12-01-2010
Maine Sail's Avatar
The US2200 is an excellent & well built battery. US specifically buids this as their T105 killer and a number of manufacturers have made the move to US from Trojan such as Yamaha and Club Car in the golf industry. This battery has severely eaten away at Trojan's market share.
The Sam's Club Johnson Controls batts are a good battery at a great price but arguably not as well built as a Trojan, US Battery or even Crown. They should still last a good long while though if cared for. If you can get the US2200 for under $100.00 it is a great value. I don't know if it is really worth any more than a $25.00 - $30.00 spread though per battery from the JC product but that is a decision you'll have to weigh...
I know many with the Sam's Club 6V's who are extremely happy with them.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #13 of 19 Old 12-01-2010 Thread Starter
Beneteau 411
Thanks. Based upon my research, I can get the Sams Club GC2 battery for $82 and the US2200 for $114 locally or $100 if I'm willing to drive 250 miles round-trip. All prices are outright (ie, not exchange) prices.
Pete
prroots is offline
post #14 of 19 Old 12-04-2010
asdf38's Avatar
So how come it makes sense to have four 6V's instead of two or three 12V's?
asdf38 is offline
post #15 of 19 Old 12-04-2010
Maine Sail's Avatar
More amp hours with 4 6V, 440-450 Ah's for 4 standard GC batteries, when compared to three 12V of a similar case size. 6V's have thicker plates internally which means longer cycle life with 6V batts than with 12V batts. Also less money $$ per Ah, and available world wide..
______
post #16 of 19 Old 12-04-2010
Four GC2 type batteries give you about 400 amp-hours at 12 VDC. You'd need to have two 8Ds to get about the same capacity, but an 8D weighs 140 lbs... and is a PITA to install or remove.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
post #17 of 19 Old 12-05-2010
asdf38's Avatar
Ok, for what its worth I ran the energy density numbers and the larger 12V's come out just a bit on top. Thats what you'd expect simply due to economies of scale.
US2200
232AH * 6V *1000 = 1,392,000 mWH
260mm*181mm*286mm = 13459160 square milimeters
Total : 0.1034 mWH per square milimeter
US 31 DCXC
130AH * 12V * 1000 = 1,560,000mWH
330mm*171mm*248mm = 13,994,640
Total: 0.1115 mWH per square milimeter
asdf38 is offline
post #18 of 19 Old 12-05-2010
Maine Sail's Avatar
US2200
US 31 DCXC
Yes and four group 31's will be 520 Ah's and four US2200's will be 464 Ah's. BUT the US2200's will last a considerably longer and take up less floor space than four group 31's. Remember that 12v batts have 6 cells in them and thus each plate is quite a bit thinner. Each 6V battery has only 3 cells thus the battery plates are much thicker and you will almost always get a longer cycle life from them.
A more fair comparison is a GC2 size to a group 24 as they are closer in floor foot print though the GC2's are slightly taller...
______
post #19 of 19 Old 03-10-2014
4arch's Avatar
Re: Best battery monitor for the buck
Iím dusting off this old thread to give a headís up that Victron is apparently discontinuing the BMV-600s battery monitor and releasing a new 700 series in its place this spring. I found one vendor (not sure if Iím allowed to state the name, but can be found with a search engine) selling the 600s on clearance for just a little over $100. This is an amazing price for a really useful device and I donít imagine it will last long. I definitely couldnít pass it up. At that price, itís cheaper than a lot of simple marine grade digital voltmeters.
s/v Spindrift
Beneteau Oceanis 400
formerly Lippincott 30
4arch is offline
The Following User Says Thank You to 4arch For This Useful Post:
MastUndSchotbruch (03-15-2014)
Battery Monitor - recommendations JLovett Electrical Systems 8 05-10-2010 07:24 AM
Looking for battery monitor suggestions jarcher Gear & Maintenance 24 04-21-2010 10:53 AM
Battery Monitor - One Bank or Two? montenido Electrical Systems 12 09-27-2009 09:54 AM
Battery Monitor trantor12020 Gear & Maintenance 4 03-06-2009 11:35 AM
Pentametric battery monitor: opinions? Valiente Gear & Maintenance 3 06-26-2008 01:16 AM
